10-06-2012, 18:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | 6303c error after flash this log: Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35603603247298-1 Product code: 0568866 Battery voltage: 4987 mV, current: 52 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356036032472981 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 |
10-06-2012, 21:39 | #3 (permalink) | |
Member: 382783 Status: Offline Thanks Meter: 124 | Quote:
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356036032472981 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 when i powered on the phone gaves Contact service | |
10-06-2012, 23:15 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-443.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
10-07-2012, 13:36 | #5 (permalink) | |
Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 35603603247298-1 Product code: 0568866 Battery voltage: 4988 mV, current: 54 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356036032472981 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 but what about this message: warning: avoid SW Downgrade & manual erase to this phone ! | |
10-07-2012, 14:45 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
You will see this in Logs when Phone is SL3, To make User Precaution to avoid killing Phone. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
