03-15-2012, 10:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | HTI On USB, what this box can do? HTI can do BACKUP/RESTORE RPL, SX4 AUTH, SUPER SD AUTH, REPAIR SD, BB5 SL3 phones by using only USB cable. Support USB just like on FBUS for RAPUv1, RAPUv2, BCM21351, RAP3Gv4. Example, let's play with backup-erase-downgrade. Step 1. Connect phone ALIVE to USB. Select phonet device as interface. Launch Nokia Module, press SCAN !! Make sure flash files are loaded after phone scanned !! Step 2. After phone is scanned, Read PM Step 3. Preceed to Backup RPL Disconnect phone. Close phonet. Choose Nokia USB ROM Step 4. Do erase phone. Click ABORT after erasing is done. That erase file is nasty, will erase the flash chip fully. Applicable for all BB5 single CPU with NAND flash chip. After this, you will need to close mobileex, and re-open it. Or simply right click on title bar, choose "Restart App" Now choose USB ROM as interface :::: Phone is erased. Now flash any version :::::: Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0696666 Using device: USB ROM and HTI, FW ver: 00.50, SN: 01001EF9 Connection status: NUSB3XHC:NUSB3HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.73 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) Processing MCU file: rm614__03.35.mcusw [BB5,XSR 1.6] size: 27.66 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000104BBD512FD69E4686046DD0DBD26F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 106B0A9 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 697F7477 [RAP Certificate v1 232] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 5.842 s Processing PPM file: rm614__03.35.ppm_x [BB5,XSR 1.6] size: 7.16 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.489 s Processing CNT file: rm614__03.35.image_x_0598883 [BB5,XSR 1.6] size: 12.36 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 2.723 s Total time for flashing process(boot+erase+write) was 18.090 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! Waiting for device boot up ... Device connected: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 1FCB7364 Verifying communication to device OK. Phone type: RM-614 (C3-00) SW version: V 03.35 15-05-10 RM-614 (c) Nokia Imei plain: 12345610654321-? Product code: 059G6Z1 Battery voltage: 3983 mV, current: 162 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC0000040102F201, ver: 001.006 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Step 5. Phone is alive, with corrupted security. Time to restore. Write readed PM backup on first step. LAST STEP Restore IMEI Code: RPL: "C:\mobileEx\3.5\data\backup\BB5_35536604659684_BACK.rpl" Imei: 35536604659684 Updating PRODUCTCODE (059G6Z1)... OK Updating PSN (752E236AI)... OK Updating HWID (2009)... OK Updating SIMLOCK(PA_SL3)...error 0x17 Trying to write SIMLOCK as PM(PA_SL3)...OK Updating WMDRM_PD ...OK MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0696666 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01001EF9 Connection status: NUSB3XHC:NUSB3HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.73 Module ver: 1.0.0.20454(13-03-2012), Library ver: 1.0.0.13962(12-03-2012) Battery voltage: 4011 mV Phone type: RM-614 (Nokia C3-00) Product code: 059G6Z1 SW version: V 03.35 - 15-05-10 - RM-614 - (c) Nokia LanguagePkg version: 5 - 15-05-10 - RM-614 - (c) Nokia - X Waiting for USB device removal ...OK Waiting for USB device arrival ...OK CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000104BBD512FD69E4686046DD0DBD26F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 106B0A9 FUR: Adding Asic CMT as client OK. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Waiting for USB device removal ...OK Waiting for USB device arrival ...OK [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! Waiting for device boot up ... Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 106B0A9 Waiting for USB device removal ... Device connected: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 18ECCDC1 Verifying communication to device OK. Phone type: RM-614 (C3-00) SW version: V 03.35 15-05-10 RM-614 (c) Nokia Imei plain: 35536604659684-3 Product code: 059G6Z1 Battery voltage: 4011 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC0000040102F201, ver: 001.006 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355366046596843 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN :::::::::: BACKUP-ERASE-DOWNGRADE-RESTORE DONE :::::::::::: Can i Repair SD by USB? YES! You can! How to repair SD by USB Step 1. Connect phone ALIVE to USB. Select phonet device as interface. Launch Nokia Module, press SCAN !! Make sure flash files are loaded after phone scanned !! Step 2. As usual, nothing special ALL DONE http://forum.gsmhosting.com/vbb/atta...8&d=1331792308 limited to using 10 images All mentioned functions above are actually exist long time ago. Made this post for those who didn't noticed These work applicable for RAPUv1, RAPUv2, BCM21351, RAP3Gv4. Precaution on RAP phone with DCC, you might be will need FBUS to write DCC in this version. BR |
The Following 36 Users Say Thank You to gbluez For This Useful Post: |
03-15-2012, 10:28 | #2 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Almost forgot. here is the nasty erase file. this file can be use with OTHER FLASHER. placed as MCU. use on your own risk will post later more tips by USB |
The Following 33 Users Say Thank You to gbluez For This Useful Post: |
03-17-2012, 01:20 | #14 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Yes, all types on mentioned baseband support only by 100% USB. Even RAPIDO. But will need help from HTI FBUS after Quote:
For stand alone mode, no need internet. You can always use Repair SD + Super SD Auth button anytime from your computer. Same function as SX4 BR | |
03-17-2012, 01:46 | #15 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: In The World
Member: 861211 Status: Offline Sonork: 000000 Thanks Meter: 127 | Quote:
thank's kang for replay my question.... | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
