06-14-2011, 22:57 | #3 (permalink) |
Freak Poster Join Date: May 2007 Location: aiurea`n tramvai !
Member: 514081 Status: Offline Thanks Meter: 82 | 1 - install manualy driver from C:\mobileEx\3.5\data\drivers\universal-ftdi 2 - remove hti interface and connect again 3 - install manualy driver from C:\mobileEx\3.5\data\drivers\hti\htibox |
06-15-2011, 02:51 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | 1st problem from incorrect smart card instalation. before u try instal hti box driver. try to uninstall all smart card, then after update firmware (if u succses updated firmware 1.17, skip updated), instal smartcard reader manually chose :hti smartcard reader(winusb) (using hti box). Last edited by ekel; 06-15-2011 at 03:01. |
06-15-2011, 03:29 | #6 (permalink) |
Registered User Join Date: Sep 2008
Member: 851587 Status: Offline Thanks Meter: 9 | well remove all driver thar u have for mx box now u should remove u mx installation too. now restart ur computer after that install ur mx software from the beginning(dont plug in ur hti), let the installation finish the job,restart the computer once again. the next step plug in ur hti to usb cable then wait the computer install the driver automatically. now try to start ur mx software. good luck.... |
The Following User Says Thank You to maxscaesar For This Useful Post: |
06-15-2011, 07:16 | #7 (permalink) | |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Quote:
let's see it. Uploaded with ImageShack.us The very first time I installed mxbox I also installed the HTI card reader.. it f.ucked my whole windows and I had to use my ghost image to restore windows to original state. Now, (i didnt install 3.5 1.0) I installed 3.5 1.1 directly, installed the drivers update and on the next step (use new drivers WinUSB) I lost the cardreader and the box cannot start. right led keep blinking (I am sure it has something to do with the faulty card reader driver) reckon I have to start over with my ghost image again, from the beginning. | |
06-15-2011, 08:58 | #8 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | how many of you guys, with working mxbox got this message Uploaded with ImageShack.us about drivers not compatibles with language. I got the same message the first time, but it worked (3.5 ver 1.0) I just havent been able to "update drivers" for USB smart card reader. and force windows to use the one at HTI directory. |
06-15-2011, 09:26 | #10 (permalink) |
Freak Poster Join Date: Feb 2000 Location: Slovakia Age: 53
Member: 965 Status: Offline Thanks Meter: 36 | solved this way disconnect mxbox device manager - show hidden devices - USB smart card reader - update driver manualy(from C:\mobileEx\3.5\data\drivers\hti) now device manager show HTI smart card reader(winusb) instead of USB smart card reader connect mxbox and work... BR Tomi |
06-15-2011, 11:15 | #11 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | someone with a working hti can upload just the hti drivers directory, to compare with the one I got? C:\mobileEx\3.5\data\drivers\hti because no matter how many times I try, windows ALLWAYS says that there is no driver better than the installed. only explanation: there must be some files missing. Code: Directorio de C:\mobileEx\3.5\data\drivers\hti 15/06/2011 12:13 <DIR> . 15/06/2011 12:13 <DIR> .. 01/05/2011 08:38 <DIR> amd64 23/12/2009 10:48 5.674 HTIBOX.cat 25/04/2011 19:05 2.374 HTIBOX.inf 10/06/2011 04:22 10.582 HTICCID.inf 10/06/2011 04:18 2.372 HTIWINUSB.inf 11/12/2009 13:05 8.974 HTIWINUSBa64.cat 11/12/2009 13:05 8.938 HTIWINUSBx86.cat 01/05/2011 08:38 <DIR> i386 19/04/2011 11:20 1.534 MXKEYCARD.inf 15/06/2011 12:13 0 text.txt 8 archivos 40.448 bytes Directorio de C:\mobileEx\3.5\data\drivers\hti\amd64 01/05/2011 08:38 <DIR> . 01/05/2011 08:38 <DIR> .. 23/12/2009 10:20 67.072 HTIBUS.sys 27/01/2011 15:18 1.721.576 WdfCoinstaller01009.dll 18/11/2009 23:21 708.168 WinUSBCoInstaller.dll 14/04/2010 04:27 2.152.176 WUDFUpdate_01009.dll 20/11/2010 15:27 116.224 WUDFUsbccidDriver.dll 5 archivos 4.765.216 bytes Directorio de C:\mobileEx\3.5\data\drivers\hti\i386 01/05/2011 08:38 <DIR> . 01/05/2011 08:38 <DIR> .. 23/12/2009 10:19 55.552 HTIBUS.sys 14/07/2009 07:27 1.461.992 WdfCoInstaller01009.dll 18/11/2009 19:21 581.192 WinUSBCoInstaller.dll 14/07/2009 07:21 1.837.296 WUDFUpdate_01009.dll 20/10/2008 18:24 53.248 wudfusbcciddriver.dll 5 archivos 3.989.280 bytes Total de archivos en la lista: 18 archivos 8.794.944 bytes |
The Following User Says Thank You to hugmax For This Useful Post: |
06-15-2011, 11:38 | #12 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | frack!! for the second time... mxbox installation has made my winXP unusuable. in my intent to make the usb card reader to work, now NO BOX is working. need to restore from ghost image again. |
06-15-2011, 23:21 | #14 (permalink) | |
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | Quote:
after u fix smartcard reader with hti smartcard reader(winusb), automaticly yellow mark on hti flasher interface (winusb) will be desepear Last edited by ekel; 06-15-2011 at 23:29. | |
The Following User Says Thank You to ekel For This Useful Post: |
06-15-2011, 23:45 | #15 (permalink) | |
hti driver.zip | |
Starting forum for ex YU members ... | legija | GSM Mobile Links | 1 | 02-11-2002 00:26 |
GET ME STARTED | igotthehookup | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-25-2001 07:56 |
antinokia flasher shell ver 2 (changing the start addresses) | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-06-2001 11:12 |
NEW site and forum START a | helpme | GSM Mobile Links | 0 | 11-03-2000 01:02 |
How do I change Start Up Logo? | Digital Man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-29-2000 15:20 |
