Old 04-02-2010, 17:22   #1 (permalink)
Member: 974162
Sonork: QuanVV
Thanks Meter: 43
HWK V2.10.00 New Feature DCT4-WD4 RPL Generating system
HWK V2.10.00 New Feature DCT4-WD4 RPL Generating system.
is this working???....Should to check....i am trying and posting result.
:PHONE INFO:
 MCU SW  : V 7.02 10-12-07 RH-93 (c) NMP
PPM SW  : V 7.02 10-12-07 RH-93 (c) NMP IA
Prd.Code: 0532991
Bpr.Code: 0532665
Prod.Sn : VF2960232
HW Vers : 0502
UEM     : 1328
UPP     : 8705 [2201]
RFIC Ver: 0500
DSP Vers: P05w06.v34
LCD Type: WIN:SYRS:01 ST7506
IMEI    : ??????-??-??????-?
SL Conf : 3B4-CF-0464F899AFA
SL Prof : BA872D30B401489-8
SL Var  : 0000FFFFFFFFFFFFFFFF
SL Aux  : 00023F3F
HW Sig  : 1EB9620C23533E2B
Box Id  : 0000000000000000
Bad SL Structure BC: 00
MastCode: ?
Provider: Not Found
   #pw+ 858 091 271 672 107 +1#
   #pw+ 839 831 550 720 745 +2#
   #pw+ 887 431 501 536 043 +3#
   #pw+ 189 924 107 741 430 +4#
   #pw+ 747 050 363 502 464 +5#
   #pw+ 334 556 752 257 361 +6#
   #pw+ 019 913 636 711 724 +7#
Reading UEM
 Warning, IMEI/ESN Backup Fail
IMEI Number: ??????-??-??????-?
1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.1.0.1]
2nd Boot: u_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE
Algorithm: u_amd.fia, , Ver: 4.79.0
UEM IMEI Num : 358068-01-765694-8
00000000: 41 F9 33 C5 FF FF 4A 45 14 32 17 31 76 33 85 60  A.3...JE.2.1v3.`
00000010: 08 71 56 96 F4 FF FF FF FF FF FF FF FF 00 00 8F  .qV.............
00000020: 34 FF FF FF FF 00 15 EB                          4.......
00000000: CD 2D C3 52 D8 95 B9 FA F7 E2 39 B1 49 08 3A E0  .-.R......9.I.:.
00000010: 46 6D 77 C6 DE 98 92 1A 35 16 12 02 8A 72 3D BC  Fmw.....5....r=.
00000020: FE EA CF 60 56 74 8C 6D                          ...`Vt.m
Ask IMEI Num : 358068-01-765694-8
Product Code : 0532991
UEM Changed  : 0
Dongle S/N   : 038442
Algorithm: u_amd.fia, Ver: 4.79.0
ASIC Detected: 2
UEM Read Done, Time: 00:01
Writing UEM
 IMEI: ??????-??-??????-?, ASIC: 2
RPL File Info:
IMEI: 35806801765694
CHCK: 7502
Warning: No DATA2 Record
IMEI: ?
PROD: ?
UEM Writing Done, Time: 00:02
Warning: No SIM_PROG_DATA in File
AFTER UPLOADING GENERATED RPL FILE
Prd.Code: 0532991
Bpr.Code: 0532665
Prod.Sn : VF2960232
HW Vers : 0502
UEM     : 1328
UPP     : 8705 [2201]
RFIC Ver: 0500
IMEI    : 358068-01-765694-8
SL Conf : 001-01-00000000000
SL Prof : 800000000001000-2
SL Var  : 00003580680176569400
SL Aux  : 00023031
Box Id  : 8BD2FFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
MastCode: 14 32 17 31 76
Provider: GSM Test Equipment
   #pw+ 784 160 000 253 072 +1#
   #pw+ 042 103 262 063 517 +2#
   #pw+ 047 543 560 567 650 +3#
   #pw+ 097 153 412 523 666 +4#
   #pw+ 148 244 666 644 653 +5#
   #pw+ 939 432 354 746 344 +6#
   #pw+ 405 207 420 374 411 +7#
UNLOCK PROCESS NEEDED
 IMEI: 358068-01-765694-8, ASIC: 2
FILE: rh93_07.020
Algorithm Ok, MSID: 84C142B14A59423AA22CB0B03E
Decoded MSID: 3E4EBAE9-008C573F-AA000000
Encoded FAID: 06FBB1B0-08EA170E-0E30107E
Area1: 0x01140000-0x0115FFFF Erased, Time: 00:00
PAT Flashing Completed, Time: 00:00
SimLocks Initialized (Patch Ok), Time: 00:00
UNP Flashing Completed, Time: 00:00
SimLocks Initialized, Time: 00:42
UI Defaults Ok, Time: 00:04
Set UI Factory Defaults Ok, Time: 00:00
Set Full Factory Defaults Ok, Time: 00:00
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
Init Normal Mode Failed, no SIM Card
NOW PHONE WORKING WELL WITH ORIGINAL  DATA
Prd.Code: 0532991
Bpr.Code: 0532665
Prod.Sn : VF2960232
HW Vers : 0502
UEM     : 1328
UPP     : 8705 [2201]
RFIC Ver: 0500
SL Aux  : 00023031
Box Id  : 894F8BD2FFFFFFFF
Here is Proof and steps I followed. I did it with RH-93 (1110i).
First Check Info:
 MCU SW  : V 5.54 16-08-06 RH-93 (c) NMP
PPM SW  : V 5.54 16-08-06 RH-93 (c) NMP MJ
Prd.Code: 0537096
Bpr.Code: 0536354
Prod.Sn : IBE647406
HW Vers : 0526
UEM     : 1328
UPP     : 8705 [2201]
RFIC Ver: 0500
LCD Type: WINTK:MYKS01
SL Conf : 999-0D-119759E5411
SL Prof : BDEBE6A9DA0124E-A
SL Aux  : 00020000
HW Sig  : D72B866DEA86B2F5
MastCode: ?
Provider: Not Found
   #pw+ 185 024 302 322 231 +1#
   #pw+ 957 162 077 563 274 +2#
   #pw+ 287 195 002 573 507 +3#
   #pw+ 389 126 007 773 737 +4#
   #pw+ 359 926 776 721 430 +5#
   #pw+ 223 015 144 172 021 +6#
   #pw+ 702 290 326 034 000 +7#
Now Press Rd UEM.
HWK will first ask you save XXXXXXXXXX_generated.rpl. This is the generated RPL file, which we will write.
After that it will ask you to save ASK file. Just save it. Now it seems useless. :D
In between this process, I pressed Yes/Ok only, nothing else. :)
Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
Algorithm: u_intel.fia, , Ver: 4.80.0
Reading UEM IMEI/ESN ...
UEM IMEI Num : 356414-01-202828-1
Ask IMEI Num : 356414-01-202828-1
Product Code : 0537096
UEM Changed  : 1
Dongle S/N   : 134623
Algorithm: u_intel.fia, Ver: 4.80.0
Reading UEM DATA ...
ASIC Detected: 2
Now simply press Wr UEM button. When asked select XXXXXXXXX_generated.rpl file made in previous step.
 Reading Info from Mobile ...
RPL File Info:
IMEI: 35641401202828
CHCK: 11054
IMEI: ?
PROD: ?
Writing UEM ...
UEM Writing Done, Time: 00:01
Now press Info and see result.
Prd.Code: 0537096
Bpr.Code: 0536354
Prod.Sn : IBE647406
HW Vers : 0526
UEM     : 1328
UPP     : 8705 [2201]
RFIC Ver: 0500
IMEI    : 356414-01-202828-1
SL Prof : 000000000001000-2
SL Var  : 00003564140120282800
SL Aux  : 00023031
Box Id  : 8BF1FFFFFFFFFFFF
MastCode: 65 44 57 15 47
   #pw+ 499 107 115 753 212 +1#
   #pw+ 329 926 444 771 037 +2#
   #pw+ 227 895 740 520 104 +3#
   #pw+ 215 195 536 313 604 +4#
#pw+ 016 943 031 401 054 +5#
   #pw+ 356 836 377 440 745 +6#
   #pw+ 849 061 762 762 077 +7#
http://www.youtube.com/watch?v=aA8hB_APgPU
The Following 4 Users Say Thank You to manhhung157nt For This Useful Post:
Old 04-02-2010, 17:37   #2 (permalink)
nazrul islam's Avatar
Member: 756569
Thanks Meter: 185
This Section For Mx Key.Not For HWK
The Following User Says Thank You to nazrul islam For This Useful Post:
NEW UPDATE...NEBULA DCT4+ Liberator v2.10 fred Universal GSM Software 2 12-01-2010 17:16
HWK V2.10.00 New Feature DCT4-WD4 RPL Generating system ..::AppleLinks::.. HWK 75 04-20-2010 05:22
Today i install ufsxhwk new exe v2.10.00 and update my hwk now i have a probem ..::AppleLinks::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 17 03-26-2010 07:01
Strange Problem of Cruiser V2.00 and V2.10 gsmdoctorca Cruiser Suite 7 01-19-2005 17:43
Page generated in 0.17001 seconds with 9 queries
