06-14-2009, 12:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | i can't make rpl from online logger ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 FlashID0: 0020 8828 [ST M58MR032] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Performing Flash Authentication ...OK UEM ID: 0040AB01A3BDA66 ASIC type: 11 UEM Imei: 35896301692944 Connecting to server ...OK, Login ... Hello C08008AE, you have 980 credits left. Invalid DATA1 length, expected: 80 chars. |
06-14-2009, 13:51 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | YA DCT4 PLUS ASIC 11 RPL ARE HAVING SOME PROBLEM MX-KEY CAN'T MAKE THEM USE THIS LINK http://forum.gsmhosting.com/vbb/showthread.php?t=764600 AND POST URE 1. MXKEY serial number (8 digits): 2. IMEI number (15 digits): 3. ASIC: Mr.MANOLE OR MX-KEY TEAM MEMBER WILL MAKE THE RPL FOR U. WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
06-14-2009, 14:00 | #4 (permalink) | |
Junior Member Join Date: Nov 2007
Member: 626307 Status: Offline Thanks Meter: 3 | Quote:
ASIC 11 not support yet | |
06-14-2009, 14:06 | #5 (permalink) |
No Life Poster Join Date: Mar 2009 Location: yasir telecom.. Age: 34
Member: 1001830 Status: Offline Sonork: 100.1652282 Thanks Meter: 242 | ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 FlashID0: 0001 327E [Spansion ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Performing Flash Authentication ...OK UEM ID: 001313A6A3BDA66 ASIC type: 11 UEM Imei: 35351502318251 Processing file: rm305_05.510 ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 FlashID0: 0001 327E [Spansion ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Performing Flash Authentication ...OK UEM ID: 001313A6:2984DA60 Programming MCU ... rm305_05.510: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 2.33 MB Area [01000000-0100FFFF] erased in 0.813 s Area [01010000-0179FFFF] erased in 48.390 s Area [017A0000-017EFFFF] erased in 2.766 s Area [01F00000-01FDFFFF] erased in 5.781 s Flash programming ... Error finalization ! Programming completed in 2 min 16.360 s File Processed in 3 min 32.094 s Processing file: rm3050_nai5.51el Performing Flash Authentication ...OK UEM ID: 001313A6:2984DA60 Programming Content Pack ... rm3050_nai5.51el: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 169.91 KB Area [01760000-0179FFFF] erased in 1.829 s Flash programming ... Error finalization ! Programming completed in 1 min 6.000 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 1.484 s File Processed in 2 min 39.719 s Processing file: rm305_05.51el Performing Flash Authentication ...OK UEM ID: 001313A6:2984DA60 Programming PPM ... rm305_05.51el: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 2.42 MB Area [01240000-0125FFFF] erased in 0.719 s Area [01260000-0175FFFF] erased in 40.171 s Flash programming ... Error finalization ! Programming completed in 2 min 25.938 s File Processed in 3 min 26.343 s MX-KEY TEAM WHATS THIS ERRORS? |
06-17-2009, 20:48 | #12 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | @.::PATEL TELECOM::. already explain by mr.sahil2000ind did u read sir ? our server still can't calculate asic 11 for right now. alternative way is explain by mr.sahil2000ind br, |
06-18-2009, 14:56 | #14 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | ASIC ID: 0x1201 [UPP_v2.1] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST M58MR016] page size: 64 K type: NOR area: 01000000-011FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B28 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00126049:2984DA60 ASIC type: 2 UEM Imei: 35538500------ Connecting to server ...OK, Login ... Hello C08------, you have 970 credits left. RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35538500-----.RPL" ASIC ID: 0x1201 [UPP_v2.1] u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST M58MR016] page size: 64 K type: NOR area: 01000000-011FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B28 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: 3533770--------- Product Code: 0513792 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Ind,Tagalog But the asic 11 is not work at that moment |
After update NK tool, i can't see Online logger | odi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-18-2010 10:59 |
Makeing RPL from PM on SL3 posible?????? | dragosgsm | Cyclonebox | 9 | 10-21-2009 23:20 |
i want to make rpl from ask file | kapilgupta | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 06-07-2009 02:03 |
nff teem can't make rpl | suneel | Nokia Fault Finder Box | 0 | 11-22-2008 14:33 |
