Old 02-12-2010, 06:46   #1 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
i can't repair 5130c-2 SIMLOCK invalid!, SIMLOCK_TEST failed!
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.94 21-07-09 RM-495 (c) Nokia
Imei plain: 35521203706511-9
Product Code: 0577793
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
The Following User Says Thank You to mohit_kripalu01 For This Useful Post:
Old 02-12-2010, 06:49   #2 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
http://forum.gsmhosting.com/vbb/showthread.php?t=920409
use search bro... Everything already posted...
ERIC
The Following User Says Thank You to ericnite101 For This Useful Post:
Old 02-12-2010, 06:51   #3 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 143
it is repairable
hhhhhhhhhhhhhhhhhhhhhhh
Old 02-12-2010, 06:53   #4 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Sure it is... Try those steps and post results...
Old 02-12-2010, 06:56   #5 (permalink)
armanhosting's Avatar
Member: 410890
Thanks Meter: 88
as of now it cannot repair with mxkey with simlock invalid only sd or security test failed simlock is not yet release of sl3 based phone....
Old 02-12-2010, 07:02   #6 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
ERIC
many time i'll try but not success Sl3 Simlock invalid not repair mx-key
Old 02-12-2010, 07:32   #7 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
first read care fully then post :d
The Following User Says Thank You to gsm_3gn For This Useful Post:
Old 02-12-2010, 10:29   #8 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
man try all thing but not success
Old 02-12-2010, 10:33   #9 (permalink)
Registered User
Member: 450799
Thanks Meter: 61
try this bro
Procedure Step by step:
1-Backup Rpl full
2- reset NPC
3- write full modified pm
4- restore imei
5- Repair SD
6- Super SD auth
7- write pm 1 and 309 field only
8- Default all setting
Old 02-12-2010, 10:47   #10 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
Originally Posted by brownline28 View Post
try this bro
1-Backup Rpl full
2- reset NPC
4- restore imei
5- Repair SD
6- Super SD auth
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.12027, Date: 06-02-2010
Product: V 06.94 21-07-09 RM-495 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 8.875 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_355212037065119_SIM.RPL"
Updating SIMLOCK...
error 0x1
Reading Simlock info ...
Updating SIMLOCK...
error 0x1
Old 02-12-2010, 10:50   #11 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
this is not support now wait next update
Old 02-12-2010, 11:10   #12 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
try this bro
1-Backup Rpl full
2- reset NPC
4- restore imei
5- Repair SD
6- Super SD auth
RPL: "C:\mobileEx\3.3\data\backup\RPL\BB5_3552120370651 1_BACK.rpl"
Imei: 35521203706511
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0570010849E07C564CF114C5C6E248704F61D839
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0571584)... OK
Updating PSN (HEC345703)... OK
Updating HWID (1000)... OK
Updating SIMLOCK...error 0x1
Trying to update SUPERDONGLE_KEY ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
Product Code: 0571584
Language Pack:
- not available.
SIMLOCK invalid!
TimeStamp: 2009-07-28T03:56:08Z
SW Version: 06.94
Variant Version: 010
ProductProfile: RM495_0571584_06.94_010.spr
Simlock: 0571584_simlock.bin
repair SD
Calculating SUPERDONGLE using security server ...
Completed in 10.469 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_355212037065119_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
Language Pack:
- not available.
SIMLOCK invalid!
SW Version: 06.94
Old 02-12-2010, 11:53   #13 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
Language Pack:
- not available.
SIMLOCK invalid!
As gsm_3gn Said, Not Supported at the Moment Till V1.4(Simlock Cannot be Repaired for this one only SD is Repairable)
Try Unlocking Mobile using Latest version, Post Result.
Regards
Old 02-12-2010, 12:04   #14 (permalink)
Member: 575629
Thanks Meter: 11
bro 5130 is not supported of mxkey for simlock data corrupted..wait for the next update of mxkey
Old 02-12-2010, 12:16   #15 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
Thanks Meter: 182
5130 sl3 not supported at the moment
wait for next update..........................
Masud
Nokia 5130c-2 SIMLOCK invalid! bassemzini MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-06-2010 05:09
6303c SIMLOCK invalid SIMLOCK_TEST failed SIMLOCK_DATA corrupted dimitron MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-25-2010 15:14
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! mohit_kripalu01 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 11:36
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! Raven21 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 01-27-2010 08:15
Page generated in 0.32670 seconds with 10 queries
