Old 01-25-2010, 05:43   #1 (permalink)
Member: 172261
Thanks Meter: 364
I can't unlock 2600c
is it not support? it same like my 2680s when unlock v56.17
Imei net: 3548710xxxxxxx
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 5555555555555555
PROFILE_BITS: 5555555555015555
SIMLOCK_DATA corrupted!
PhoneType:RM-340
SwVersion: V 07.60 10-04-09 RM-340 (c) Nokia
MCU file: rm340__07.60.mcusw
Trying to find patch position ...OK, case id: 4
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 008B39E0:3B8ADA60
Area [01000000-0101FFFF] erased in 0.465 s
Area [01080000-0109FFFF] erased in 0.385 s
Area [01AC0000-01ADFFFF] erased in 0.383 s
Programming ...
Programming completed.
Phone not responding !
after unlock = dead
v7.60 not suppoerted????
Old 01-25-2010, 05:49   #2 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
reflash in other tool, upgrade then unlock again..
Old 01-25-2010, 05:52   #3 (permalink)
=Deftones='s Avatar
Member: 557796
Thanks Meter: 187
flash it into it's original verion.........
and unlock it.......
The Following User Says Thank You to =Deftones= For This Useful Post:
Old 01-25-2010, 06:12   #4 (permalink)
Member: 124943
Sonork: 100.1573954
Thanks Meter: 19
flash it again new version and try and unlock
Old 01-25-2010, 06:17   #5 (permalink)
=Deftones='s Avatar
Member: 557796
Thanks Meter: 187
don't try other version just flash it into it's original version if you have it.......
Old 01-25-2010, 06:21   #6 (permalink)
alex_samsat's Avatar
Member: 759701
Thanks Meter: 29
Don't use MCU file: rm340__07.60.mcusw for this case...
I predict imei number are 11xx..not 35xxx
Old 01-25-2010, 06:48   #7 (permalink)
Member: 172261
Thanks Meter: 364
why eveytime i [bus check] it must no respone, i test with few phone
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11826, Date: 22-01-2010
FlashID1: 0000 0001 [unused/removed]
UEM ID: 001D52E1A3BDA66
ASIC type: 11
UEM Imei: 3593130xxxxxxx
Flash Imei: 3593130xxxxxxx
MasterCode: 0574622720
RPL saved to "C:\mobileEx\3.3\data\backup\3593130xxxxxxx_BACK.r pl"
but if [scan] all fine
Phone Type: RM-340 (Nokia 2600c-2)
SW Version: V 06.82 26-09-08 RM-340 (c) Nokia
Imei plain: 3593130xxxxxxx-2
Imei OTP: 3593130xxxxxxx
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: S
Language Pack:
- not available.
TimeStamp: 2008-11-05T08:19:43Z
SW Version: 06.82
Variant Version: 042
ProductProfile: RM340_0556667_06.82_042.spr
Simlock: 0556667_simlock.txt
Imei net: 3593130xxxxxxx
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Pleeease help! can't unlock 2600c vs. 7.60 flydog Cyclonebox 2 12-18-2009 11:58
CAN'T UNLOCK 2600C-2B LOCK AT&t sunshinelin Cyclonebox 1 08-06-2009 06:01
can't unlock 2600c-2b AT&T hlep!!!! sunshinelin Cyclonebox 8 07-21-2009 14:45
A35-can't flash, can't unlock, can't log! Migeni x1x to x45/x50 4 12-21-2002 12:17
Page generated in 0.17479 seconds with 10 queries
