Old 02-14-2010, 21:49   #1 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Cool I fixed flashing error with UFS in bb5 no rx buffer!!!
Here's how to fix error in bb5 flash rx buffer
- first install 3.3 rev 1.6 and signed
- install 3.2 rev 5.4 not signed and is already signed
- for flashing use 3.2 rev 5.4 and bring back the date 2009
- for unlock/repair use 3.3 rev 1.6
- working run both versions on the same os
- be tested dct4.
Version from phone: 35.0.001
Version from file: 35.0.001
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 2D24AE18B2C86EF863659040B123D454C11CD8D6
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 15500109F6740052DAD68A026D4C4299A58C77DE
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0
RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00
Supported APE Ids: 24200703, 24200704, 24200705, 24200706
RX2 enabled.
FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80
APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
Reading RAP NPC (0x1B8 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Reading APE NPC (0x200 bytes).
Reading APE VARIANT (0x0 bytes).
Reading APE CCC (0x200 bytes).
Reading APE HWC (0x200 bytes).
Flash Imei: 35684202625097
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
NPC_DATA saved OK
VARIANT_DATA is empty.
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_35xxxxxxxxx_B ACK.rpl"
Processing file: RM-320_35.0.001_PR.C0R as MCU
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 69.48 MB
Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
Supported APE Ids: 24200705
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
Total erase size: 123.00 MB
CMT NOR area [00080000-007CF385] erased in 30.296 s
CMT NOR area [00000000-0005FFFF] erased in 0.672 s
CMT NOR area [00880000-00FDFFFF] erased in 6.312 s
APE NAND area [00000200-0000AFFF] erased in 0.047 s
APE NAND area [0000B800-000AFFFF] erased in 0.047 s
APE NAND area [00000000-00000FFF] erased in 0.047 s
APE NAND area [0000D800-0000E9FF] erased in 0.031 s
APE NAND area [00080000-000BFFFF] erased in 0.031 s
APE NAND area [000E0000-0045FFFF] erased in 0.062 s
APE NAND area [004C0000-0073FFFF] erased in 0.063 s
APE NAND area [00A40000-06F3FFFF] erased in 1.078 s
Flash programming ...
Valid PAPUB key found
CMT PAPUBKEYS, RAP Certificate 96 v1 written.
APE PAPUBKEYS, APE Certificate 96 v1 written.
Programming completed in 6 min 9.641 s
Processing file: RM-320_35.0.001_PR.v01 as PPM
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 16.20 MB
Supported RAP Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 4003192101011103, 4003192101031103, 400C192101031103
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
Total erase size: 30.00 MB
APE NAND area [05140000-06F3FFFF] erased in 0.344 s
Programming completed in 1 min 26.188 s
Processing file: RM320_31.0.002_025_xxx_U01_uda.fpsx as CNT
[BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 39.30 MB
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
Total erase size: 137.31 MB
APE SOS-USER
APE NAND area [06F40000-0F87FFFF]
erased in 0.047 s
Programming completed in 3 min 31.234 s
Flashing completed in 12 min 54.109 s
Phone Type: RM-320 (Nokia N95 8GB)
SW Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia
Imei plain: 35xxxxxxxxxxx
Product Code: 0557876
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei: 35xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 13 min 3.391 s
BR,
gprsman.
The Following 2 Users Say Thank You to gprsman For This Useful Post:
Old 02-15-2010, 06:47   #2 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
let me know for dct4.........
BR.
Old 02-15-2010, 17:31   #3 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
until they fix these bugs with UFS this trick is great
BR.
The Following User Says Thank You to gprsman For This Useful Post:
how you solved the bug in flash in BB5 FBUS RX buffer with error? gprsman MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-12-2010 19:57
k750 flashing error with ufs umakishore Sony Ericsson Hardware Repair 0 05-18-2008 16:34
6600 flashing error with ufs please help nizoudj WD2 & APE (Symbian Phones) 6 08-15-2007 09:01
7280 flashing error with UFS reo Nokia Digital Core Technology 4 ( DCT-4 ) 7 03-20-2005 23:13
9210 flash error with UFS-3 ur3ec_Andy UFS2 + UFS3-Tornadoflasher 6 06-02-2004 07:12
Page generated in 0.19392 seconds with 10 queries
