02-28-2012, 16:40 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 356169 Status: Offline Thanks Meter: 34 | i need hellp Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\35895401566810_BA CK.rpl). Processing MCU file: rh99_06.000 [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] Error sending bootloader ! flashing terminated ! |
02-28-2012, 16:47 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. already 1 thread with this & again. check usb to box cable, if ok then may be bugs can fix in next update, but searching here & there dont open your box for hardware as your box must ok. i will confirm you & post again. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
02-29-2012, 11:57 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C06029FF Using device: HTI, FW ver: 00.50, SN: 01001E28 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00F148FDA3BDA66 ASIC type: 11 UEM Imei: 35419803387532 Flash Imei: 35419803387532 MasterCode: 6453014315 RPL saved to "C:\mobileEx\3.5\data\backup\35419803387532_1330454445_BACK.rpl" Phone type: RH-122 SW version: V 03.10 11-02-09 RH-122 (c) Nokia Imei plain: 35419803387532-3 Product code: 0575925 Cellular system: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MD Language Pack: English,Filipino,Vietnamase Master code: 1765353362 Imei net: 35419803387532 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
The Following User Says Thank You to gbluez For This Useful Post: |
02-29-2012, 13:17 | #5 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | @ ZuberChaudhary & Gbluez very cleaver example. the man is getting error in nokia 1200 & u are replying for nokia 1661.. if u have not understood the matter, then have a look at the forum. we can see the problem of ERROR SENDING BOOTLOADER in few models like 1200,1208,1650,1110. not all DCT4. more info can be found here: http://forum.gsmhosting.com/vbb/f550...rules-1405049/ plz have a time to rectify the problem then answer. regards..... |
02-29-2012, 17:32 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
02-29-2012, 18:02 | #7 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | i replied u after checking all possible errors from my side. u know i have 3 mx boxes.1green & 2 orange boxes. all of them are getting same problem in dct 4 models. for your king info i also changed cable & i am using gpg original A to B cable and my all other boxes are working fine in that cable... do u have more option??? let me know your pc configuration 1st. |
02-29-2012, 18:48 | #8 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. my pc is win xp sp3 with 1gb ram. not so special kind of pc its old acer laptop working with all software fine & bro. 1 thing i will tell you the most important is installing & updating in right way following product expert's procedure will never face problems or error. |
02-29-2012, 19:10 | #10 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | what solution bro. when there is no problem. i gave you the screen shot of rh-99 ok buscheck, for that phone which you are getting error. means something wrong with cable, HTI update or mxkey installation. |
02-29-2012, 19:35 | #11 (permalink) |
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | why are u over reacting bro? u mean i am lying? look here. http://forum.gsmhosting.com/vbb/f550...wered-1398994/ http://forum.gsmhosting.com/vbb/f550...roblem-988603/ http://forum.gsmhosting.com/vbb/f550...wered-1401176/ http://forum.gsmhosting.com/vbb/f550...wered-1433585/ |
02-29-2012, 19:43 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. no no no i am not telling that you lying. i know you are not lying but read my last line, its a actual solution from my point of view. i am just trying to help you bro. |
03-01-2012, 00:21 | #13 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
UPP ID 3040, 2292, 2293, 3162, 3166, 3168 use the same approach. one bug, all bugs. rabi, all your link are malfunctioned boxes. as i said, there is no bugs. use other tools if you insist. | |
03-01-2012, 09:05 | #14 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
a lot of possibilties here bro @rabi malfunctioned boxes mean the boxes are damaged (whose fault is it?), not the bugs in software. am i right or wrong? peace bro... br | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
