Old 10-06-2012, 16:19   #1 (permalink)
Crazy Poster
Member: 1118992
Sonork: 100.1622295
Thanks Meter: 3
1616-2 RH-125 Flashing ok not pw on‎
FLASHING OK BUT
Old 10-06-2012, 16:37   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Post Buscheck Logs,
If Logs Ok then check LCD ways or Change LCD will solve it.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-06-2012, 17:14   #3 (permalink)
Crazy Poster
Member: 1118992
Sonork: 100.1622295
Thanks Meter: 3
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C086D45D
Using device: HTI, FW ver: 00.50, SN: 00016640
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Phone type: RH-125
SW version: V 06.51 13-05-11 RH-125 (c) Nokia
Imei plain: 35201704825439-3
Product code: 0595840
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MG
Language Pack:
English,Hindi,Marathi
Imei net: 35201704825439
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-06-2012, 18:24   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
2 Block regions:
EBL ready !
Phone type: RH-125
Ppm Id: MG
Language Pack:
Counter: 0/3, 0/10
it's LCD fault change LCD solved your problem 100%
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 10-06-2012, 19:59   #5 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
2 Block regions:
EBL ready !
Phone type: RH-125
Ppm Id: MG
Language Pack:
Counter: 0/3, 0/10
check bsi line
by mobile care
The Following User Says Thank You to imrankhan0143 For This Useful Post:
Old 10-07-2012, 05:35   #6 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 96
post self test log here..................
The Following User Says Thank You to unuunu For This Useful Post:
Page generated in 0.14460 seconds with 8 queries
