08-10-2010, 08:04 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Khyber pukhtom khwa (D.I.KHAN) Age: 34
Member: 442499 Status: Offline Sonork: 00737 Thanks Meter: 80 | MANOLE InternalErrorFault] Receive Timeout (case id=0xCB01) SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000A590EA3BDA66 ASIC type: 11 UEM Imei: 35196003333763 [InternalErrorFault] Receive Timeout (case id=0xCB01) |
08-10-2010, 09:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Same problem ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00965066:2984DA60 ASIC type: 2 UEM Imei: 35274601489002 [InternalErrorFault] Receive Timeout (case id=0xCB01) |
The Following User Says Thank You to kabul For This Useful Post: |
08-10-2010, 12:13 | #10 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pAK+Africa
Member: 1190193 Status: Offline Sonork: 1619687 Thanks Meter: 406 | ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00063A65:2984DA60 ASIC type: 2 UEM Imei: 35551301720499 [InternalErrorFault] Receive Timeout (case id=0xCB01) |
08-10-2010, 13:16 | #11 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Incredıble !ndıa
Member: 113243 Status: Offline Thanks Meter: 77 | same problem ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004D0F63A3BDA66 ASIC type: 11 UEM Imei: 35416502326507 [InternalErrorFault] Receive Timeout (case id=0xCB01) |
f_loader for flash id 00898892 (5130).plz help!!!! | wonkypants | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-09-2001 19:59 |
I need protocols for sending/receiving SMS and data with NOKIA 5110 over a serial cab | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-18-2001 17:33 |
Problem with 5110 (amd's flash's) ID=000122DA | GSM-CZ TM&HM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 01-24-2001 02:36 |
case closed nokia 5110 v5.28 unlocked | king76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-08-2000 08:48 |
