Old 02-09-2010, 01:31   #1 (permalink)
nunu.gabriel's Avatar
Member: 857353
Thanks Meter: 14
Lightbulb MX-KEY on windows sp2 problem
Double-click .... and nothing !!!
I wait...and wait.... NOTHING !!! Any ideea ?
I don`t have virus...i use KAV 2010 !! I disable the antivirus and NOTHING !!
Mx-key is compatible with procesor core2duo 2Ghz intel ? T7250 ?
On p4 3Ghz single core work perfect !!!
Thk manole ...i wait you answer !!!
Old 02-09-2010, 01:59   #2 (permalink)
Member: 460280
Thanks Meter: 73
Maybe your anti-virus blocked the start-up of mxkey, add mxkey to exclusion. It always happen to those who are using kaspersky.
JHON Q.
Old 02-09-2010, 04:02   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can be from pkey driver to ,
not install correctly
br,
Old 02-09-2010, 05:28   #4 (permalink)
Member: 1225331
i already experienced that problem, my solution is uninstall the kav, ang install another antivirus,
now my problem is solved! i am using avast 4.8 now.
Old 02-09-2010, 08:23   #5 (permalink)
Member: 1144271
Sonork: kuldeep_sharma2k7
Thanks Meter: 62
i am use windows xp2 my mxkey working vell ... this is u r anti vires problem
Old 02-09-2010, 08:34   #6 (permalink)
Registered User
Member: 320752
Thanks Meter: 30
http://www.microsoft.com/downloads/d...displaylang=enuse dotnetfx your problam answer
Old 02-10-2010, 00:43   #7 (permalink)
badwily's Avatar
Member: 241933
Thanks Meter: 77
i have the same problem. today i recived my mx key and i cant run on xp sp2 ,nothing happen, i use KIS 7.0 (kaspersky) , i already try remove old smart drivers, install framework , and add mobileEx to exclusion on KIS, and nothing.
i dont want remove KIS because i like this antivirus.
Any other sugestt/ solutions
Old 02-10-2010, 10:05   #8 (permalink)
Member: 164253
Thanks Meter: 4
uninstall KIS 7.0 (kaspersky)
Old 02-10-2010, 20:48   #9 (permalink)
badwily's Avatar
Member: 241933
Thanks Meter: 77
problem solved works fine
see this pictures
http://forum.gsmhosting.com/vbb/show...6&postcount=12
Solving the problem exclusively CONTACT Surf 5130 MX-KEY on the video without the nee haythamangel MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-22-2010 19:39
Is mx key supports windows 7 Kethey MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-08-2010 22:51
Us of now where the bomb of mx-key on sl3 unlocking,this is a dream can true??? RCB Telecom MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 12-18-2009 05:57
installation of mx-key on other pc Mind Power MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-21-2009 10:04
Page generated in 0.16664 seconds with 9 queries
