Old 02-10-2010, 15:38   #1 (permalink)
Member: 1232758
imei invalid
hii
i got a 6300 from cust which was going off on nokia display.. i flashed with jaf with latest version and backup RPL also.. but now when i put it on it says contact service.....
the phone can be repired with mx key or not?
logs
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 12345610654321-?
Product Code: 0573527
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
"RM-217" folder created.
Imei plain is invalid !!!
Imei net: 12345610654321?
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1:   1=CORRUPTED
any body has the solution
how to restore RPL back to the phone?
Old 02-10-2010, 15:59   #2 (permalink)
Member: 1232758
after doing simlock RPL
now the logs
Language Pack:
- not available.
SIMLOCK_TEST passed
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
1st step completed.. now how to do the rest?
Old 02-10-2010, 16:07   #3 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
go to service> imei rebuid> click write rpl and select ur rpl
Old 02-10-2010, 16:27   #4 (permalink)
Member: 1232758
after writing back the rpl log shows
Imei: 35319103359322
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 2F00021184B67B56551F5B324141F36732C48939
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208  - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 1.40.0 revision: 0.0 size: 0x22C10
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
NPC verified Ok.
Updating CMT  NPC ...OK
Updating CMT  CCC ...OK
Updating CMT  HWC ...OK
Certificate programmed successfully !
shall i upload my rpl? is thr ny thing wrong with my rpl?
Old 02-10-2010, 19:09   #5 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
brother write ur rpl back up with jaf ur mobile 100./. will ok
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 3 06-09-2015 08:56
Nokia 8800 arte RM-233 Imei invalid after usb flash .::MD_AKTER::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 07-09-2010 03:23
plz mx key help me for 3110c SERVER: Imei invalid or empty (12345610654321?)! boussoula MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-26-2010 12:58
5200 imei invalid pallumobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-18-2010 12:59
Page generated in 0.15155 seconds with 9 queries
