03-21-2010, 12:14 | #1 (permalink) |
Junior Member Join Date: Apr 2006 Location: RAHIM YAR KHAN PAKISTAN
Member: 254496 Status: Offline Thanks Meter: 2 | Imei plain is invalid !!! here is log ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005332E2A3BDA66 ASIC type: 11 UEM Imei: 01154000229210 Connecting to server ...OK, Login ... Hello C0807D3D, you have 2010 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\01154000229210.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 005332E2A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-106 SW Version: V 5.32 05-18-08 RH-106 (c) NMP Imei plain: ??????????????-? Product Code: 0563363 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! |
5130 problem IMEI plain is invalid | shreedid123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 25 | 03-25-2010 11:43 |
[HELP]nokia 6600 Imei plain is invalid !!! | Delon | Nokia Hardware & Hardware Repair | 2 | 03-08-2010 20:51 |
hel 7310c Imei plain is invalid !!! SIMLOCK_DATA corrupted! | sofiame2006 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-08-2010 11:01 |
5310 x Imei plain is invalid | it_teba | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 01-31-2010 00:15 |
