Old 02-24-2011, 11:30   #1 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
INFO: How to repair security test failed
i have seen many threads started just asking the same question about security test failed
all of us know that mxkey has perfectly solved contact service caused by security test failed
some just too lazy to search
if the phone is in contact service condition, and shows the log like this:
SIMLOCK valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST failed!
these are the steps to solve it:
1.
First of all u need good pm with SX4
( do SX4/super sd auth after that pm1 and pm309 )
2.
if not solved then
check CCC and HWC certificates
How to repair CCC and HWC certificates ?
backup RPL than open it in notepad
there u will see NPC data after that CCC data and HWC data
just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model )
3.
if still not solved then
recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON
4.
Repair SL
REPAIR SD
SUPER SD AUTH
write PM1 and PM309
5.
if still same then
make RPL backup
full erase
then flash
then rpl
then Repair SL
then SD repair
then super sd auth
then PM 1 and 309
i just hope no more new threads started everyday asking about security test failed problem again
good luck
br
ps: the solutions are quoted from this forum too, thanks to who posted for the 1st time, i forget who posted it before...
The Following 6 Users Say Thank You to specta For This Useful Post:
Old 02-27-2011, 09:19   #2 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
additional:
How to repair Superdongle ( phone restart in every 3 minutes):
1. if the log is like this:
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
in this case, to solve it:
a.press repair Super Dongle
b.then SD Auth PM
c.then write good pm including fields pm1 and pm309
d. update splock (by ticking init simlock & make simlock rpl) if needed (just for sl2)
2. if the log is like this:
SIMLOCK passed!
SUPERDONGLE_KEY passed!
SIMLOCK_TEST passed
b.then SD Auth PM
c.then write pm1 and pm309 only (or u can tick load rfbb from server to write from server)
if after repair sd, u found problem in security test failed, then u can try the steps mentioned above...
good luck bro
br
The Following 2 Users Say Thank You to specta For This Useful Post:
Old 02-27-2011, 14:29   #3 (permalink)
Member: 1323194
Thanks Meter: 61
Nice work bro
Today i will check and tell u
Old 02-02-2012, 08:33   #4 (permalink)
Member: 113162
Thanks Meter: 17
wow...wow... who is ur teacher bro??
Old 02-02-2012, 08:36   #5 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 762
bro its too long just make a tutorial and shere here
Old 02-02-2012, 08:47   #6 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
u are my teacher bro
i thought i have your permissions to share it with others
br
Old 02-02-2012, 08:50   #7 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
it is not too long bro, there are few options if u failed on one, but surely one of the options will solve your problem for sure.
and don't forget the date i posted it, it was long long ago before hti was invented and no standalone sx4
br
Old 02-02-2012, 08:56   #8 (permalink)
Member: 1714279
Thanks Meter: 16
please post link............
Old 02-02-2012, 09:07   #9 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
google it, u can find it, or seach it in 4share, i just did, the file still exists, im not sure if im allowed to post outside link here
br
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.35518 seconds with 8 queries
