Old 10-17-2011, 07:22   #31 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
good work
Old 10-17-2011, 09:46   #32 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by sumatera View Post
Check vbat output from RJ45 = 5v
if not, change this IC (code BCP69) take from old jaf
Bro,
Please, can post one photo for to know which is the point "vbat output from RJ45 = 5v"???, don't are many expert in these thinghs, but if do u know to me which is this point for ceck, i ceck the value and if not is 5V i change this IC, becouse my MX-BOX never hare read only 1 phone by direct RJ45 cable, only one time but whith the "UFC V2 Adapter",
thank for your answere and pardon for my English,
Regards
Allumts
Old 10-18-2011, 01:02   #33 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Originally Posted by allumts View Post
Bro,
Regards
Allumts
plug your fbus cable,
measure voltage on battery pins.
at least 4 volts
Old 10-18-2011, 06:12   #34 (permalink)
Member: 332522
Thanks Meter: 28
Bro,
Regards
Allumts
Test between red an black aligators clip on UFC V2 Adapter if voltaje is minor of 4v change transistor
Old 10-18-2011, 07:04   #35 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
forgot to say. open nokia module first, and test.
box will not produce any voltage before you open a module.
Old 10-18-2011, 21:25   #36 (permalink)
otto68's Avatar
Member: 394446
Sonork: 100.1579789
Thanks Meter: 74
bro you say void garantee
But it is cheaper to just buy new one for shipping is costly and customs is even worst
The Following User Says Thank You to otto68 For This Useful Post:
Old 10-19-2011, 07:56   #37 (permalink)
Member: 1149774
Sonork: 0313-9541047
Thanks Meter: 1,163
nice work gbluez.......
regard
Old 10-24-2011, 03:41   #38 (permalink)
johnaccell's Avatar
Member: 1215525
Thanks Meter: 25
this true solution. tested by me.
thanks for sharing.
Old 10-25-2011, 16:54   #39 (permalink)
Member: 195958
Thanks Meter: 4
am also having the same problem. thanx for the post let me try it
Old 10-26-2011, 15:05   #40 (permalink)
Member: 835033
Sonork: luca
Thanks Meter: 22
Hi Gblues,me too after update now the Mx box can't boot any phone and there is no way to back this box to reseller cause I am too far from my reseller and It is just ten days since I received this tool,
Please I need help mr gblues.
thanks.
Old 10-27-2011, 13:15   #41 (permalink)
Member: 195958
Thanks Meter: 4
After updating my mxbox, it refuses to detect phone. I changed the ic and it is still the same, I checked the voltage=6.2v. I became confused because I dont know what to do next . At the down bar, it shows( BSI set to :1k )and also shows {BSI(soft TMA)set to :1k). Please help me, my box is 3days old.
Old 10-27-2011, 13:26   #42 (permalink)
Member: 195958
Thanks Meter: 4
please help where can I find the ic kf33 in the mxbox board.
Old 10-28-2011, 01:03   #43 (permalink)
unlock_allgsm's Avatar
Member: 1678945
Sonork: 100.1620753
Thanks Meter: 107
Originally Posted by festino View Post
mxbox shows eBB5protocolType:OLD. PLEASE HELP ME
I think you updated you mx box firmware but during update you lose connection just update your firmware again
Old 10-28-2011, 12:05   #44 (permalink)
Member: 195958
Thanks Meter: 4
thanks, but after another update it still show the same thing please help me
Old 10-31-2011, 07:21   #45 (permalink)
Member: 1202336
Sonork: 100.1609163
Thanks Meter: 29
only 3.95 volts after several changes!
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.26346 seconds with 10 queries
