10-31-2011, 10:31 | #46 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
I've find more of one transistor from old "Furious Box II" or from one old Modem adsl, one of this is C02D-1723, from FUrious Box II is this: D9005K3-7533-1, are good for change?, now my MX-BOX Not read any Nokia Phones, but for the Syncronie Files is ok, the fw is Full updatate, i cannot used my BOX whith any cables from Original GPG becouse not detect these, but is possible that 10 MX BOX over 10 are all demaged?, yes i have buyed for resell these and no only one detect phone, WHY this?, is possible change the transistor , for test, whith one of write above?, Thank you BR Allumts | |
11-01-2011, 22:08 | #48 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1176529 Status: Offline Thanks Meter: 0 | i have a similar issue, it does not read any bb5 phone, but it does read dct4 phones, can still be the same problem? allready instal and uninstall and update 3times, still the same, this problem came along with update to 3.5 rev 1.4 |
11-18-2011, 11:11 | #53 (permalink) | |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | after chang this ic working 1000000000000000000000% Quote:
for scan and Bus check also for flashing too thank for sumatera | |
11-25-2011, 17:06 | #55 (permalink) |
Major Poster Join Date: Sep 2004 Location: yap
Member: 82476 Status: Offline Thanks Meter: 4 | now it reeds the phone but i cant flash it. its this error: Boot error: CC CC CC 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try. I did another hti firmware update but the same problem. Any solution? |
11-29-2011, 10:26 | #57 (permalink) | |
Regards Allumts | |
11-29-2011, 10:36 | #58 (permalink) | |
Br Allumts | |
12-01-2011, 11:59 | #59 (permalink) | |
Excuse me, are not practical and do not understand anything about electronics, I found, after much research, the transistor BD-140, replacing the BCP-69, I have difficulty welding BD-140 because it only has 3 legs, while the BCP-69 has 4, you can show me how I should solder this with 3 legs in a very simple, I would be grateful to those who show me so simple and so many acronyms how to replace it, thank you in advance BR Allumts | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
