02-09-2010, 14:38 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Invalid DATA1 length, expected: 80 chars. Invalid DATA1 length, expected: 80 chars. Where is Prob ? Regards |
02-12-2010, 18:15 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | why i get this error while connecting the logger.... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009965EA:2984DA60 ASIC type: 2 UEM Imei: 35623204281170 Connecting to server ...OK, Login ... Hello C080A53C, you have 2010 credits left. Invalid DATA1 length, expected: 80 chars. |
02-12-2010, 18:28 | #7 (permalink) |
Member: 158032 Status: Offline Thanks Meter: 331 | Here is now server ok but not sucess full any one help me out of this problem.... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009965EA:2984DA60 ASIC type: 2 UEM Imei: 35623204281170 Connecting to server ...OK, Login ... Hello C080A53C, you have 2010 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35623204281170.RP L" ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 009965EA:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-4 SW Version: V 8.11 19-06-06 RM-4 (c) NMP 2300 Imei plain: ??????????????-? Product Code: 0514085 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: AD903D2C6D65A3DA PROFILE_BITS: A870C378EBE45782 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
Invalid DATA1 length, expected: 80 chars. | spkhmer | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 38 | 05-02-2010 16:39 |
Invalid DATA1 length, expected: 80 chars. | Formingus | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-09-2010 13:59 |
Invalid DATA1 length, expected: 80 chars. | M Maqsood | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-06-2010 14:18 |
@mx-key team Invalid DATA1 length, expected: 80 chars. | TechPhone | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 11-13-2009 13:09 |
Invalid DATA1 length, expected: 80 chars. | akt007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 10-25-2009 09:47 |
