Old 10-11-2012, 10:14   #1 (permalink)
Member: 60993
Thanks Meter: 22
nokia c6 hang problem
i have nokia c6 hang on nokia logo i try to flash with last ver
how to solve this problem
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: RM-612_42.0.004_prd.core.C00
[BB5,XSR 1.6] size: 111.93 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 12E00010BD7D02526CF6B10B2B7E80648F3D0CAC
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 207.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 46.359 s
Processing PPM file: RM-612_42.0.004_prd.rofs2.V43
[BB5,XSR 1.6] size: 31.33 MB
Erase size: 48 MB
CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 29.891 s
Processing PPM file: RM-612_42.0.004_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 7.96 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.078 s
Processing CNT file: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx
[BB5,XSR 1.6] size: 2.68 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT SOS*ENO block sent
Programming completed in 2.625 s
Processing CNT file: RM-612_42.0.004_uda_1_001.uda.fpsx
[BB5,XSR 1.6] size: 56.92 MB
Erase size: 283.75 MB
CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF]
Programming completed in 1 min 15.390 s
Total time for flashing process(boot+erase+write) was 3 min 53.578 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 8FA84A3
Verifying communication to device OK.
pls help me
Old 10-11-2012, 10:29   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
What is your Phone Product Code?
Flash it with Latest Firmware of your Phone Product Code,
Use FBus Cable for this if not solve.
BR,
ZUBER
Page generated in 0.13754 seconds with 8 queries
