Old 10-10-2012, 16:29   #1 (permalink)
Member: 797068
Thanks Meter: 75
E75 RM- 412 error and not unlock!!!
Imei net: 359557014044XXX
Version: SIMLOCK SERVER
Provider: T-Mobile Austria GmbH , Country: Austria
Counter: 0/3, 0/10
CONFIG_DATA: 2320300000000000
PROFILE_BITS: 8000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=23203F [Austria-T-Mobile Austria GmbH ]
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: XXXXXXX
Using device: HTI, FW ver: 00.50, SN: XXXXXXX
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Phone type: RM-412 (Nokia E75)
SW version: V ICPR72_09w09.2 27-05-09 RM-412 (c) Nokia
ApeCoreSw: 110.48.125
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 07C0000EEF7C0052E71B036FD5FF6958373044F0
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
ERROR: Configuration request failed !
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80
Reading Simlock info ...
Counter: 0/3, 0/10
Old 10-10-2012, 16:39   #2 (permalink)
Member: 797068
Thanks Meter: 75
Imei net: 35955701404xxxx
Counter: 0/3, 0/10
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: xxxxxxx
Using device: HTI, FW ver: 00.50, SN: xxxxxxxxx
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Unknown ID !
Error getting boot info !
ERROR: bootstrap failed!
Imei net: 3595570140xxxxxx
Counter: 0/3, 0/10
Old 10-10-2012, 16:54   #3 (permalink)
Member: 797068
Thanks Meter: 75
is not SL3 this read on the SL3Loger
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN:xxxxxxx
Using device: HTI, FW ver: 00.50, SN: 0xxxxxx
ERROR: Invalid SP BLOCK or Not a SL3 phone !
Old 10-10-2012, 20:42   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Post Unedited Buscheck Logs.
It's SL2 Phone.
BR,
ZUBER
Old 10-10-2012, 21:10   #5 (permalink)
Member: 797068
Thanks Meter: 75
Support please, i need unlock this phone !!!!!
It's SL2 Phone.
BR,
ZUBER
Do not get it!! i need unlock this phone
Old 10-10-2012, 21:28   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Needs Buscheck Logs to identify where problem is.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-10-2012, 21:32   #7 (permalink)
Member: 797068
Thanks Meter: 75
OK i post bush check log´s thansk and wait solution!!
BR,
ZUBER
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: xxxxxxxx
Using device: HTI, FW ver: 00.50, SN: 0xxxxxxx
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: C29DF97EC55AABC28ACB9029D2E577CA237E7179
Original Imei: 35955701404469
Original Product code: 0583491
Bluetooth ID: 001E3AF10271
WLAN ID: 001E3B062BF1
SIMLOCK PA identifier:
[0] PA_SL2
Imei plain: 35955701404xxx-3
Battery voltage: 4772 mV, current: 3 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359557014044xxx
Counter: 0/3, 0/10
Old 10-10-2012, 21:36   #8 (permalink)
Member: 797068
Thanks Meter: 75
I tried and it was now, I thank the attention!
Counter: 0/3, 0/10
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
PRIVATE ID: 10EF61FBAD8DE6BEF5A1F35AC098A36D80A81A0A
E-FUSE: 0AC8CFBF
SEC ROM CRC: 3E691FF8
Restarting phone ...
Updating SIMLOCK ...OK
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-10-2012, 21:44   #9 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Buschecked OK,
Try again,
Go to Service Tab > Tick Init Simlock & Click Update SPLock,
Post reply.
BR,
ZUBER
Old 10-10-2012, 21:45   #10 (permalink)
Member: 797068
Thanks Meter: 75
i work thanks my brother
Buschecked OK,
Try again,
Post reply.
BR,
ZUBER
http://forum.gsmhosting.com/vbb/f550...0/#post8832786
Page generated in 0.31195 seconds with 8 queries
