12-16-2010, 10:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 43
Member: 23004 Status: Offline Thanks Meter: 21 | LCD version: UNKWN Version Info: MCU SW version: V 6.00 30-09-09 RH-99 (c) NMP HW version: 2502 UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR62_08w31_UPP LCD version: UNKWN: IDs: 7f:ff:7f PPM version: V 6.00 30-09-09 RH-99 (c) NMP AF ADSP SW version: p V 6.00\n30-09-09\nRH-99\n(c) NMP\naf Product Info: Production serial number: IQA498098 Product code: 0546960 Module code: 0203402 Basic production code: 0564638 Serial Numbers: IMEI warranty: 356424021703782 IMEI plain: 35573????????????? IMEI spare to net: 3A 55 37 03 02 19 16 05 IMEI SV to net: 33 55 37 03 02 19 16 75 F2 Other Info: CS type : GSM/DCS1800 BSI: 3.3 KOhm Imei net: 35573302091615 Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following 2 Users Say Thank You to ALNOOR For This Useful Post: |
12-16-2010, 11:17 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | broth change lcd strip or connect direct lcd to board without strip n check if not just rehot upp it should worj if ur board connect is ok |
12-16-2010, 17:56 | #7 (permalink) |
Insane Poster Join Date: Dec 2010 Location: +919934071161
Member: 1469596 Status: Offline Thanks Meter: 6 | I think lcd unknown is hardware issue, 1. first change strp nd lcd 2. change lcd conecter 3. check continutity nearby resistances. 4. then check value on these resistances. 5. if value miss any of these resitance, then reball cpu or change cpu. that post should be on harware section. wbr santosh4gsm |
12-16-2010, 21:18 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | just answer a question.....is ur display working perfectly or is it just the problem with the message showign as LCD version: UNKWN: IDs: 7f:ff:7f |
6110 LCD Screen | gsmxc | Nokia Hardware & Hardware Repair | 4 | 06-26-2004 06:03 |
How to adjust LCD contrast on 5110? | mastergsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-29-2001 21:00 |
6110 and 3210 LCD Screen | pks | Nokia Hardware & Hardware Repair | 12 | 04-24-2001 12:45 |
8890 LCD SCREEN | erikiiy | Nokia Hardware & Hardware Repair | 0 | 12-21-2000 23:37 |
6110 LCD Contrast Changing??? | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-14-2000 18:52 |
