Old 03-07-2010, 16:16   #1 (permalink)
Member: 408058
Thanks Meter: 371
loader not responding (0910000000B172)
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Processing file: RM84_50737301.C0 as MCU
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
Supported APE Ids: 17100701, 17100702
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: 95C02A23FE28310F21E2D37BBAF415EF272B0635
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 154001086A9A5A51F6719585BA8FC6DA9AC282B5
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Flashing terminated with error(s) in 34.250 s
RX Buffer: 0910000000B172
Old 03-07-2010, 16:18   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
change cable if not then change flash directory if not then use jaf interface
Old 03-07-2010, 16:31   #3 (permalink)
Member: 408058
Thanks Meter: 371
allso try not work plz help me...................
Old 03-07-2010, 17:04   #4 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
this error only comes when we connect the set with HWK interface , use JAF as interface it will work ..
Old 03-07-2010, 17:04   #5 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
last solution is flash with ufs3 box w/o mx key
k800i Bypass loader not responding ! anz76 SE Power Clip & Turbo Unlocker 2 01-27-2010 02:39
solution for ..loader not responding.. trio1 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 01-22-2010 07:44
k800i Bypass loader not responding ! john_john SETool2 6 03-26-2009 01:48
T303 cant laod id loader loader not responding Unlocksupport SETool2 0 01-15-2009 14:35
"Ram loader not responding to Commands" problem thonda Sharp 0 12-05-2006 17:45
Page generated in 0.15530 seconds with 9 queries
