08-17-2009, 05:34 | #1 (permalink) |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | logger password problem I can go into support area and change my password but every time i am getting same error. serial no.C08025F2 reseller : gsm solution username ; triminity br. |
10-02-2009, 14:33 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | done all that checked username also changed password but still same now have only one attempt left > Connecting to server ... > Login to nkrpl.biz:13*** ... > SERVER: Invalid username or password ! You have used 4 out of 5 login attempts, After 5 fail, you will be unable to login for 5 minutes. > Disconnected from server. |
10-03-2009, 08:30 | #8 (permalink) |
Freak Poster Join Date: Feb 2008 Location: chhattisgarh India
Member: 698592 Status: Offline Sonork: 100.1645954 Thanks Meter: 18 | > Connecting to server ... > Login to host.nkrpl.biz and host2.nkrpl.biz > SERVER: Invalid username or password ! You have used 4 out of 5 login attempts, After 5 fail, you will be unable to login for 5 minutes. > Disconnected from server. i have a same problem.....and dct4 server showing Connecting to server ...OK, Login ... Hello xxxxxxxx, you have 1000 credits left. but mxlogger inviled username and password........pls help me...thank.... |
10-06-2009, 15:55 | #9 (permalink) | |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
# 02.10.2009 06:15:35 Connecting to server ... # 02.10.2009 06:15:35 Login to nkrpl.biz:13999 ... # 02.10.2009 06:15:37 Disconnected from server. # 02.10.2009 06:15:37 > SERVER: Invalid username or password, please check your details and try again ! # 02.10.2009 06:16:33 Connecting to server ... # 02.10.2009 06:16:33 Login to nkrpl.biz:13999 ... # 02.10.2009 06:16:35 Disconnected from server. # 02.10.2009 06:16:35 > SERVER: Invalid username or password, please check your details and try again ! # 02.10.2009 06:18:37 Connecting to server ... # 02.10.2009 06:18:37 Login to nkrpl.biz:13999 ... # 02.10.2009 06:18:39 Disconnected from server. # 02.10.2009 06:18:39 > SERVER: Invalid username or password ! You have used 3 out of 5 login attempts, After 5 fail, you will be unable to login for 5 minutes. # 02.10.2009 06:25:26 Instance Closed. # 02.10.2009 06:31:35 Connecting to server ... # 02.10.2009 06:31:36 Login to nkrpl.biz:13999 ... # 02.10.2009 06:31:37 Disconnected from server. # 02.10.2009 06:31:37 > SERVER: Invalid username or password ! You have used 4 out of 5 login attempts, After 5 fail, you will be unable to login for 5 minutes. # 02.10.2009 06:33:37 Connecting to server ... # 02.10.2009 06:33:37 Login to host1.nkrpl.biz:13999 ... # 02.10.2009 06:33:39 > SERVER: Invalid username or password ! You have used 5 out of 5 login attempts, access temporary blocked for 5 minutes. # 02.10.2009 06:33:39 Disconnected from server. # 02.10.2009 06:33:51 Instance Closed. # 06.10.2009 20:33:30 Connecting to server ... # 06.10.2009 20:33:30 Login to host1.nkrpl.biz:13999 ... # 06.10.2009 20:33:30 Disconnected from server. # 06.10.2009 20:33:30 > SERVER: Invalid username or password, please check your details and try again ! # 06.10.2009 20:34:02 Connecting to server ... # 06.10.2009 20:34:02 Login to host1.nkrpl.biz:13999 ... # 06.10.2009 20:34:03 Disconnected from server. # 06.10.2009 20:34:03 > SERVER: Invalid username or password, please check your details and try again ! # 06.10.2009 20:34:28 > Connect failed: Socket operation timed out # 06.10.2009 20:34:52 > Connect failed: Socket operation timed out # 06.10.2009 20:41:53 Connecting to server ... # 06.10.2009 20:41:53 Login to host1.nkrpl.biz:13999 ... # 06.10.2009 20:41:54 Disconnected from server. # 06.10.2009 20:41:54 > SERVER: Invalid username or password ! You have used 3 out of 5 login attempts, After 5 fail, you will be unable to login for 5 minutes. # 06.10.2009 20:42:10 Instance Closed. | |
10-06-2009, 18:02 | #12 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: in your hert
Member: 618615 Status: Offline Thanks Meter: 85 | solution Quote:
i have same problam plz fowlow these steps uninstal new version and install version 3.2.40 then goto servises and goto mx loger plz tick use dongle id and give last pasword that u changed last time and press logon all ok if u want imei repair plz selet dct4 or dct4+ and press do seletted job after few secend all ok plz use old version in new version not have mx loger the best option but it removed in new version | |
10-06-2009, 18:12 | #13 (permalink) |
Member: 618615 Status: Offline Thanks Meter: 85 | dear hasnain bhai plz use old version 3.2.40 and in yhe main sofrwear plz goto servises then goto mx loger (under the rebaild rpl imei) plz goto mx loger and tick on use dongle id and give password press logon 1000 cridits ok if you want imei repair plz select dct4 or dct+ and press do seleted job after few secend all ok and 10 cridits less from your a**** and if u want only rpl then tick on manual and give imei no if u like my post plz pray for me thanks by raza ahamad |
Online Logger Login problem | mehedi.h.j | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-07-2010 01:24 |
6230 MMC Password Problem | Kris_Stuart69 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-23-2005 17:39 |
HELPPP for a a800 password problem | tezzaaaaaaaaaa | VLSI, Conexant, Skyworks and Old Models | 5 | 11-03-2004 21:22 |
New T300 with logger 712 Problems | *MaTeOoSh* | Sony Ericsson | 5 | 02-07-2003 20:20 |
