01-12-2010, 20:46 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | resolve Security Test on 5800 I'am a new user in this small and in the same time bix box , I have one 5800 security test failed, usualy with other box I get SX4 and after write field 1 and 309, but this not resolve my probleme, anny help or information pls ?, I use search boutton like all the time but don't find anny think, Best Regards, JAVA Good. |
01-13-2010, 02:37 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | sound like after repair SIMLOCK / SUPERDONGLE with UB / MT can u do PMM Auth / SX-4 with MXkey service ? security test failed : can be CCC or HWC not sync or empty ( ussualy after erase / modify ) but in this case phone have protected frimware,that make not easly to repair. try with cross frimware flashing, and repair that. better put info log here br, |
The Following User Says Thank You to Andra For This Useful Post: |
01-13-2010, 11:12 | #3 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hoooo, tks for your reply, I can get SX4 with Mx-Key with out probleme, and write field 1 and 309 like many time with other box, but can't repaire security test, about write CCC and HWC, normaly I can write it with out probleme why I need cross flash the phone, this is only for write back the field 308, and my field 308 is good, I have a charging probleme, and after many search I see some peopel can repair this only with flasing, if don't work, I go to hardware probleme, Best Regards, JAVA Good. |
01-14-2010, 17:56 | #9 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | hi, I write your file and get the SX4 and after this write the field 1 and 309, but security test failed again ? realy strange, if I erase all and restore my field 308 with cross flash and restole all, this can correct the probleme ? Best Regards, JAVA Godd. |
01-15-2010, 12:33 | #11 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | maybe my customer get it back for me, I share the back up of RPL I have with cyclone, and why you speack about credit, Mxkey have some option with credit ? (sorry for this question because I'am new in Mxkey ) Best Regards, JAVA Good. |
01-15-2010, 17:52 | #13 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | I'am verry tired, I don't share my RPL file, forget sorry, I resole my probleme, just bad field 1 and 309, I test an other one and all is good, tks for you MobileEx-Team, and have a stupid question, where is unlock boutton on Mxkey ? Best Regards, JAVA Good. |
01-16-2010, 07:43 | #15 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
Goto Service TAB > IMEI and Security their u see Simlock Option Click on it now click SPLock Info to see if all is ok with your SIMLOCk then Press update Splock ..(make sure init simlock is ticked) Hope u get it | |
Cant Repair Security Test Failed on N96 and 5800 | powerplay83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 23 | 02-09-2010 17:51 |
HELP MX TEAM NOKIA 5800 RM 428 security test failed!!!! | michael garcia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-08-2010 02:22 |
5800 security test failed contact service,done | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 4 | 02-06-2010 21:08 |
5800 contact retailer security test failed sx4 not sucess. why?????? | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 22 | 02-02-2010 14:33 |
security test Fail nokia 5800 [SOLVED] | langin | Cyclonebox | 10 | 01-10-2010 22:34 |
