11-26-2011, 13:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: deveselu
Member: 543935 Status: Offline Thanks Meter: 59 | to manole or gbluez in romanian language and english [UnauthorizedFault] Card [C085FEB3] is BLOCKED (case id=0xCC02) please contact your reseller to fix the problem. Card activation task completed. Te rog sa-mi deblochezi acest card pentru ca l-am cumparat acum 2 luni cand nu aveati nici o problema cu ipmart. Pot sa postez factura de paypal si cea de ipmart daca este nevoie, ceea ce nu cred ca ar fii cazul. Multumesc pentru timpul acordat version in english by google Now about two months if I remember correctly I bought two full HTI, and I turned just a box + card, the second one I have not worked because we did not need him now, (C085FEB3) of which shows that is blocked [UnauthorizedFault] Card [C085FEB3] is blocked (case id = 0xCC02) please contact your reseller to fix the problem. Card activation task completed. Please unlock me this card that I bought 2 months ago when you had no problem with ipmart. Can I post a paypal invoice and the ipmart if needed, what if I do not think it would be. Thanks for your time |
11-26-2011, 14:22 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | You card belong to this, if your English is not enough to understand, i will translate for you in Romanian if you want: 5. This cards numbers attached list will remain blocked: Code: C085C10E C085C065 C085C09F C085C093 C085BE83 C085BE18 C085C075 C085BFD7 C085BEB2 C085BF15 C085BF24 C085BFB1 C085C16C C085C05E C085BDFF C085C15B C085BE4B C085BE99 C085BEBE C085BEF5 C085C0AE C085BE71 C085BE55 C085C038 C085BE78 C085C03E C085BE3A C085C16F C085AC58 C085BF3E C085C175 C085BF50 C085C0E6 C085BFC0 C085C0D1 C085BF8D C085C0D5 C085C044 C085BFE5 C085C180 C085BF44 C085BE27 C085BF08 C085C134 C085BEAC C085BEDE C085C0B2 C085AF84 C085BF92 C085BCB0 C085BDD8 C085C1A2 C085FD1D C085FD2D C085FD86 C085FCE8 C085FFAE C085FF47 C085FEFF C085FF7B C085FD33 C085FFDF C085FF3E C085FCCE C0860018 C085FF94 C085FFF3 C085FFBA C085FD63 C085FF9E C085FD4C C085FD59 C085FCBE C085FF2D C085FCAF C085FC8F C085FCA0 C085FF2F C085FF2C C085FC36 C085FFE9 C085FD54 C085FD47 C085FD72 C085FCA2 C085FF92 C085FFBE C085FD36 C085FF79 C085FD70 C086000A C0860005 C0860010 C085FD46 C085FCAA C0860019 C085FFB2 C085FCD8 C085FC6F C085FC97 C085FD4E C085FCF6 C085FF6A C085FD32 C085FC77 C085FCA4 C085FFF1 C085FD0E C085FDB4 C085FC83 C085FF97 C085FC43 C085FCD2 C085FFD4 C085FF4B C085FCFF C085FFD0 C085FD39 C085FD1B C085FCB8 C085FDBC C085FC90 C085FC86 C085FC53 C085FD1A C085FD79 C085FFBC C085FF34 C085FCDA C085FCD9 C085FF50 C085FDF5 C085FD25 C085FD16 C085FFC2 C085FCF5 C0860016 C085FF89 C085FCF7 C085FD80 C085FD93 C085FC3B C085FC7A C085FD88 C085FCFC C085FD05 C085FDE6 C0860013 C085FF30 C085FFCB C085FD34 C085FF99 C085FFEA C085FD09 C085FF87 C085FC98 C085FD28 C085FF46 C085FFB3 C085FF76 C0860011 C085FF59 C085FC76 C085FD62 C085FC4B C085FC49 C085FFDC C085FC7F C085FDE0 C085FFE4 C085FDBF C085FD37 C085FE0C C085FD58 C085FC38 C085FDA6 C085FF74 C085FF00 C085FD78 C085FC70 C085FC58 C085FF71 C085FF91 C085FF9F C085FF2A C085FFD8 C085FD12 C085FF36 C085FF57 C085FF17 C085FD07 C085FD7B C085FF8D C085FE11 C085FF4D C085FDC6 C085FFF6 C085FFE8 C085FF3F C085FD08 C0860012 C085FC67 C085FC91 C085FC52 C085FFB4 C085FC75 C085FC7C C085FDDA C085FD30 C085FCC2 C085FF98 C085FC4D C085FD42 C085FF84 C085FCDE C085FDCB C085FD27 C085FCF4 C085FFAA C085FCEC C085FCB6 C085FDB8 C085FFFA C085FD22 C085FD48 C085FF73 C085FD56 C085FC35 C085FC85 C085FC81 C085FC68 C085FC3F C085FF7A C085FC54 C0860001 C085FF0C C085FFC0 C085FC72 C085FCA1 C085FFE5 C085FCDD C085FDBD C085FDA1 C085FFB0 C085FC71 C085FC4F C085FC64 C085FC4E C085FD51 C085FC5F C085FD15 C085FD2B C085FFB1 C085FE2E C085FCAB C085FD18 C085FCB0 C085FD3A C085FF0B C085FFA8 C085FEF9 C085FFEF C085FD03 C085FE09 C085FD7A C085FD98 C085FFAD C085FCE3 C085FCDF C085FDFD C085FCD6 C085FF1B C085FCEE C085FC55 C085FD04 C085FD90 C085FD11 C085FF8E C085FC6E C085FC8B C085FCED C085FD6A C086000C C085FD69 C085FF0D C085FCDC C085FDC0 C086000E C085FC9E C085FCCA C085FF66 C085FCEF C085FDC9 C085FF6B C085FC3D C085FF49 C085FF06 C085FCDB C085FDA7 C085FE1D C085FDD6 C085FD14 C085FCC5 C085FCB2 C085FD2F C085FF62 C085FE24 C085FD9F C0860007 C085FD3D C085FF78 C085FFF4 C085FDA9 C085FD7D C085FFA7 C085FFE1 C085FDC1 C085FCD1 C085FC65 C085FF83 C085FF4F C085FD64 C085FD49 C085FD8C C085FFAC C085FD3E C085FD87 C085FFBF C085FD40 C085FDA8 C085FD6E C085FD57 C085FD67 C085FD31 C086001A C085FE22 C085FC99 C085FD5A C085FDE8 C085FF6F C085FD35 C085FE1F C085FC7B C085FCB5 C085FCFB C085FF1F C085FF7F C085FCCF C085FC6B C085FCC1 C085FC7D C085FC40 C085FD65 C085FD21 C085FEF1 C085FFC8 C085FC3C C085FC5D C085FFD6 C085FCE6 C085FFC3 C085FD7C C085FC78 C085FCEA C085FFEC C085FD2E C085FFAF C085FCF3 C085FD13 C085FD9C C085FD0A C085FCF2 C085FC69 C085FF29 C085FD9A C085FC48 C085FD0B C085FF75 C085FDEC C085FC94 C085FD5E C085FD41 C085FFA1 C085FD71 C085FD6D C085FD74 C0860002 C085FD10 C086000B C085FF7C C085FCA9 C085FCAE C085FD52 C085FCAD C085FF72 C085FD3B C085FD50 C085FDBE C085FD44 C085FFFF C085FC6C C0860015 C085FD8B C085FC87 C085FF33 C085FD83 C085FC61 C085FDB1 C085FD5D C085FD4B C085FF39 C085FCBB C085FD17 C085FFA2 C085FFC4 C085FC73 C085FFD9 C085FFCE C085FF95 C085FC42 C085FD68 C085FCC3 C085FFA0 C085FCCB C085FF5F C085FC74 C085FC5A C085FD99 C085FF19 C085FF61 C085FF23 C085FF5C C085FCA5 C085FFB7 C085FCE7 C085FC37 C085FD66 C085FD8F C085FFDD C085FD1E C085FF8F C085FC9F C085FFD1 C085FF26 C085FFC5 C085FFE0 C085FD5B C085FF4C C085FCEB C085FF56 C086000F C085FF4A C085FEB8 C085FED7 C085FDC8 C085FE98 C085FDD7 C085FE06 C085FDE1 C085FFF9 C085FEC2 C085FEA2 C085FDCE C085FE7E C085FED6 C085FEFD C085FC50 C085FDEB C085FEEF C085FFB8 C085FFBB C085FE9B C085FE64 C085FF77 C085FF38 C085FFF8 C085FF1A C085FDC3 C085FFA9 C085FDA0 C085FD82 C085FD9D C085FF9A C085FECA C085FDAB C085FD29 C085FDEF C085FDE4 C085FE37 C085FD73 C085FEB3 C085FE08 C085FE66 C085FD9B C085FFD7 C085FC8C C085FD4F C085FF3B C085FFDA C085FE8C C085FEE5 C085FF32 C085FE36 C085FEAB C085FF0A C085FE89 C085FFA3 C085FE05 C085D55D C085FDE9 C085FDB7 C085FC93 C085FDAD C085FE3F C085FE10 C085FCD5 C085FD5F C085FE26 C085FDF6 C085FE04 C085FF09 C085FEF8 C085FD89 C085FF08 C085FFA4 C085FEF5 C085FEFC C085FF52 C085FCFD C085FC47 C085FE0B C085FDFE C085FEF0 C085FF1D C085FD94 C085D82B C085FDE5 C085FD23 C085FF5E C085FF20 C085FF04 C085FEAA C085FD8A C085FE2D C085FECF C085FE6C C085FD1F C085FF0E C085FC82 C085FC41 C085FE6F C085FC45 C0860003 C085FF54 C085FEF3 C085FC5B C085FC95 C0859642 C0858121 C0857FC5 C0857F6C C08582A9 C08522BC C085970E C085956B C08597D6 C0859697 C0855803 C0852174 C08523DA C08564D9 C08570DE C085960B C08586ED C0855AE0 C0855FBA C0847818 C08477CB C08597C1 C085589B C08557D9 C08522A2 C0857FC6 C0847D1D C085651B C0847855 C08558E5 C0859292 C085520D C08559C8 C08565E7 C08470F6 C0846F46 C0847E49 C0855CDC C08597D3 C0846FCF C0855CB6 C08565BF C085642A C0847736 C08541F6 C0859682 C0847723 C0859702 C08595E0 C08560C3 C08565AD C0857096 C0855C1B C0856520 C08564B6 C0857079 C0856620 C085651C C08565A6 C0859320 C0855FDF C085653A C08559EB C085593F C085651D C0859302 C08565A2 C0855894 C085655A C085587E C0856429 C0855C60 C0855A6C C0855B4C C0855C44 C085931A C0855986 C0855A77 C0855A34 C0859306 C08564D8 C0856605 C08564D2 C085588A C085656F C0857080 C0856606 C08564E0 C08562F3 C08565CD C08561E7 C08558DD C0855BAF C08558D0 C0856395 C08565E5 C0855F1E C0855973 C0856033 C085622F C0855880 C08592E6 C085652F C0856589 C08564B0 C08565FA C085592D C0857090 C085603B C085626A C085651A C08559FD C08564A8 C0855985 C0855A7E C0856643 C08565E9 C0856641 C0856535 C0855976 C0857065 C08559A0 C08564C8 C0857095 C08564A9 C08592AB C0855ADF C0857067 C0855B5A C0855A23 C085654F C08559D4 C08565D5 C08561EE C08564D3 C0856508 C0855A02 C0856577 C08564EF C085621E C0855C05 C0856494 C0855B1D C0856541 C08565B6 C085651E C0855B31 C086B26F C085516C C0855397 C08556E0 C0847E37 C0855595 C084710C C0855798 C085519D C08551CB C0855436 C08557AD C08551CE C08553BC C0855708 C08557AE C08551C2 C0855338 C08551ED C08553D5 C085564E C08551E9 C085551F C0855188 C08557BA C08551FE C08551F4 C08551B3 C08551C9 C085568B C08553C9 C085519E C08553D1 C084778D C08476A7 C08470C9 C0847ADC C0847E85 C08472B7 C084716F C08475BD C08479BA C084758E C0847EB2 C0847856 C08524DD C08522D9 C085271D C0852A2A C0852044 C0852832 C0852869 C0852B08 C085227C C085280B Explanation: these were sent to IPmart for warranty exchange but he decided to sell them. This cards should be sent back to IPmart and request him for a refund. |
11-26-2011, 16:04 | #3 (permalink) |
Member: 543935 Status: Offline Thanks Meter: 59 | 2 mx/mox hti buyed in 18 oct 2011 an one from 2 are blocked see the photo. ---- intelege si tu ca am cumparat 2 boxuri dintre care unul nu mai merge, si chiar daca ar accepta ipmart sal trimit inapoi nu miar convenii mie, transportul costa in jur de 50€, eu te inteleg si pe tine imi dau seama de ce au incercat ei sa faca, dar intelegema si tu pe mine, ce vina am eu, in ziua de azi banii se castiga ff greu, chiar daca este ieftin mx-ul nu pot cumpara lunar cate unul. Last edited by cocosel; 11-26-2011 at 16:10. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
