03-15-2010, 09:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | To Manole & Mxkey team (Read this) Many n73 and same like that models after sd repair showing "Security Test Failled" . am tested lot of idea's and also asked to some one and also tried some one .all result are SAme( failled) the problem was after sd repair showing security test failled. am try to " Recover Cert" . option then showing this error ERROR: No certificate found in the database before am faced same this problem and also am solved many times with "Recover Certificate' option. anyway "Mx-Key Is The Best Nokia TooL" Regards, WAJID PNR |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
03-15-2010, 09:31 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | yes sure its best tool just wait they know every thing Quote:
03-15-2010, 09:33 | #5 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
u can write another N73 CCC&HWC then check it post result | |
03-20-2010, 10:45 | #9 (permalink) |
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Mr. Manole , After New Update also not solved this problem , then also we are watting,.....Coz Mxkey Can Do this, please solve this .... B4 am solved this successfully now showing "ERROR: No certificate found in the database " i think no certficate in server. Regards. WAJID PNR. |
03-20-2010, 10:59 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | there are many and different each product code, cos limited database we are sorry about that. usually N73 need VARIANT not CCC or HWC. do BB5 Secure Validation , and what you get ? please paste here br, |
03-20-2010, 15:57 | #12 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143656 Status: Offline Thanks Meter: 27 | how to solve security test failed? this happens always after repairing invalid security dongle...and it will always result to security test failed. do the following to solve security test failed: -go to pm tab -upload pm(pm1 and 309 necessery) pm area should be set to rf and bb parameters only -do sd authorize -then write pm everything should be ok now...100 percent tested... |
03-20-2010, 16:03 | #13 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: under women...U_D_E_L
Member: 1194626 Status: Offline Thanks Meter: 34 | Quote:
mxkey is the best unlock tool....not for flashing......:d | |
03-20-2010, 16:14 | #14 (permalink) | |
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
i think u dont hav good experiance in mxkey ,datz way u talking like this am tried all solutions for solving this problem this also tried , | |
03-21-2010, 08:47 | #15 (permalink) | |
Can u upload cetificate with variant rpl file (which inside server) need that if something possible please do that coz many n73 pending for this work Regards, WAJID PNR. | |
To manole & alim hape, read this !! | VODAFONES | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 03-07-2010 06:50 |
Valentine Gift from Manole and mxkey team | bowei | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 29 | 02-14-2010 23:16 |
SAY THANKS AGAIN FOR MR. MANOLE AND MXkey TEAM.. HERE..... | nanoy | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 02-06-2010 06:13 |
Let us respect the good work of manole and mxkey team | obioha | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-03-2010 22:54 |
SAY THANKS TO MANOLE... AND MXkey TEAM.. | nanoy | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 33 | 02-03-2010 16:13 |
