Old 06-03-2011, 19:04   #1 (permalink)
Member: 4571
Thanks Meter: 20
Nokia 5230 BF
After brute force i guet these master code:
33d44c1fe985a3ceca886bb37b71cdad4104be70:003548450 412161100:000405050907040102020701030809
after calculation in mx-key always wrong code, maybe codes are wrong??? who can help me? Thanks a lot
BLOCK1: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=21402F#pw+ 759623577060280 +1 #
#pw+ 361399136558526 +2 #
#pw+ 146837655928686 +3 #
#pw+ 216741985398161 +4 #
#pw+ 567632694076840 +5 #
#pw+ 205772103808252 +6 #
#pw+ 560314315650411 +7 #
These codes not working, include #pw+ 560314315650411 +7 # ??? always wrong code????: mad:
Old 06-03-2011, 21:06   #2 (permalink)
Guilherme Lima's Avatar
Member: 1508533
Thanks Meter: 45
Use option RESET COUNTER and try again.
The Following User Says Thank You to Guilherme Lima For This Useful Post:
Old 06-03-2011, 21:11   #3 (permalink)
Member: 4571
Thanks Meter: 20
I had do that, the problem is, when i insert code anyone always apperas wrong code. Maybe codes are not right, ????
Old 06-03-2011, 21:35   #4 (permalink)
Member: 1508533
Thanks Meter: 45
Try doing a flash and then repeat the procedure to unlock.
Old 06-03-2011, 21:40   #5 (permalink)
Member: 4571
Thanks Meter: 20
I had did these, i had flashed the mobile, but the problem is the same, can someone make a new calc with my mastercode , to see if the codes are the same as mine? Thanks a lot for your help
Old 06-04-2011, 13:21   #6 (permalink)
Member: 4571
Thanks Meter: 20
Problem solved
[IMEI]
354845041216110
[TARGET_HASH]
33D44C1FE985A3CECA886BB37B71CDAD4104BE70
[MASTER_SP_CODE]
c:\354845041216110.cod
right codes:
#pw+410721935908824+1#
#pw+423577176424888+2#
#pw+840201789639089+3#
#pw+581924097710689+4#
#pw+277664970984907+5#
#pw+148435201135311+6#
#pw+401286094518450+7#
Thanks a lot for all who help me, the problem was i was doing mistake puting right imei in calculation.
Page generated in 0.15910 seconds with 9 queries
