03-02-2010, 09:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Akay Institute of mobile tech.
Member: 732084 Status: Offline Thanks Meter: 122 | [Merged] ONLY POST HERE Servers are down - will be informed when it is up and runing pls help why SD Repair server down Calculating SUPERDONGLE using security server ... Connection refused Connection refused Connection refused ERROR: could not connect to server! |
The Following User Says Thank You to gunjan1 For This Useful Post: |
03-02-2010, 09:43 | #8 (permalink) |
Registered User Join Date: Jan 2008
Member: 687071 Status: Offline Thanks Meter: 55 | I have also network problem during dct4 rpl: ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00068324A3BDA66 ASIC type: 11 UEM Imei: 35322003633533 Connecting to server ...Socket error (10060): Connection timed out |
03-02-2010, 10:01 | #12 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Already discussed here http://forum.gsmhosting.com/vbb/showthread.php?t=940332 |
03-02-2010, 10:04 | #15 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1173492 Status: Offline Thanks Meter: 27 | Using cached productData[0CB00115448F7C563BE986E28C7043C8FC59C213] ... Calculating SUPERDONGLE using security server ... Connection refused Connection refused Connection refused ERROR: could not connect to server! help me manole |
Primary Support Site is up and runing as normal | MicrostarGSM® | MT-BOX | 20 | 07-20-2007 06:42 |
!!!GOT is no more free. You will be informed in a short time how you can get non-free | afra.com | GOT Motorola | 9 | 01-14-2007 16:02 |
When will support be up and runing | daveyy | Phoenix Black Box | 9 | 09-10-2005 03:42 |
my p800 dosen`t turn on when it is on it only stand`s sony ericson | mr_louis | Sony Ericsson | 2 | 01-17-2005 13:43 |
