Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-06-2015, 16:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | MICROMAX A65 custom rom Android 4.4.1 Thanks to a xda membeber ,original post [INDEX]Micromax A65 [ROMs/Kernels/Recoverys/Guides] - XDA Forums ** New Battery Savings Custom Kernal v5 is replaced with stock kernel.** I modified A65 to " Ultimate Evolution 4.2". And then customized a little bit. 1. Micromax Bolt Logo changed with this logo 2.Boot and shutdown animation is changed. 3. Whatsup is now system application. 4. sysem browser replaced wih Dolphin Browser. 5. Build.prop replaced with custom battery saving and improved touch , gprs setting build.prop. 6. Custom recovery C.W.M 6.0 pre-installed. 7. All Micromax built-in application are Removed for saving extra phone storage. 8. This Rom is Pre-Rooted. (you need to care about that). 9. Theme is based on samsung J.B . 10. And many other useful application is installed. And Finally its my hard work to present you a custom rom which is flahable with Original Flaasher . Any way as it is PAC file you can flash it with any chiness phone flashing box like Piranha, Volcano, Dragon, Miracle etc. Or you can modify it by C.W.M which is pre-installed. but I Failed to enter recovery mode with hardware switch combination . So I did "usb debugging" on, then from my pc type command adb reboot recovery here is the custom rom>>https://www.dropbox.com/s/2u42psknwd...A65_t.rar?dl=0 driver and downloader >> drivers and downloader tool |
