10-08-2009, 11:10 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | MobiEX 3.2 rev 5.2 WD2 PPM Flashing I have tried to flashing some WD2 phonmes, still problem on PPM flashing always error..... Please resolve this problem.... thks |
10-08-2009, 13:14 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem with flashlin latest version 3.0 rev 5.2- Here is the log- Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 8A1E 2A83 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0D7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Sorry, Unable to find flashloader for this FlashID ! And working fine with the old version 3.2 rev 5.0, here is the log- Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D61CFE:2984DA60 ASIC type: 2 UEM Imei: 35567420817460 Flash Imei: 35567400817460 MasterCode: 1731205740 Invalid imei checksum ! Phone Type: RH-59 SW Version: V 6.42 30-06-06 RH-59 (c) NMP 2600 Imei plain: ??????????????-? Product Code: 0518411 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MM Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Counter: 0/3, 0/10 CONFIG_DATA: 42B1CABEBB5A8245 PROFILE_BITS: B0F0378998B66346 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! Plz look for this bug. |
10-08-2009, 13:16 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Forgot to say one thing more, the response time in new version is too long means it takes long time to response for phone while in older version the response time is short. Last edited by PASSIONATE_BOYS; 10-08-2009 at 13:22. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-09-2009, 03:34 | #11 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 50
Member: 44531 Status: Offline Thanks Meter: 5 | Ver 4x flash unlock OK Unlock Code: Imei net: 35312202280234 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! PhoneType:RM-340 SwVersion: V 05.61 18-04-08 RM-340 (c) Nokia MCU file: rm340__05.61.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 5 ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:3B8ADA60 Area [01000000-0101FFFF] erased in 0.421 s Area [01080000-0109FFFF] erased in 0.407 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:3B8ADA60 Area [01000000-0101FFFF] erased in 0.438 s Area [01080000-0109FFFF] erased in 0.406 s Programming ... Programming completed. Completed in 1 min 13.266 s Reading Simlock info ... Imei net: 35312202280234 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
10-09-2009, 04:21 | #12 (permalink) |
Member: 44531 Status: Offline Thanks Meter: 5 | Ver 4x Flah ok Code: Using device: J.A.F, FW ver: 01.B1 Rpl backup already exist. Processing file: rm340__05.61.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 10.70 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:3B8ADA60 Area [01000000-0101FFFF] erased in 0.438 s Area [01020000-01C3FFFF] erased in 38.437 s Flash programming ... Programming completed in 5 min 57.234 s File Processed in 6 min 53.438 s Processing file: rm340__05.61.image_opv_cmcc_fetion as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 5.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:C5A4DA78 Area [02000000-02DBFFFF] erased in 1 min 26.484 s Area [02DC0000-02F9FFFF] erased in 11.828 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 2 min 47.985 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.047 s File Processed in 4 min 58.875 s Processing file: rm340__05.61.ppm_rcm as PPM [DCT4,DCT4 ALGORITHM] size: 2.86 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:2984DA60 Area [01C40000-01FFFFFF] erased in 12.282 s Flash programming ... Programming completed in 1 min 28.093 s File Processed in 1 min 56.000 s Flashing completed in 13 min 49.281 s Phone Type: RM-340 (Nokia 2600c-2) SW Version: V 05.61 18-04-08 RM-340 (c) Nokia Imei plain: 35312202280234-7 Imei OTP: 35312202280234 Product Code: 0556677 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: RCM Language Pack: - not available. Imei net: 35312202280234 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! Total time to process is 14 min 5.032 s |
10-09-2009, 05:03 | #14 (permalink) |
Member: 44531 Status: Offline Thanks Meter: 5 | Flash by ver 5.2 Code: Using device: J.A.F, FW ver: 01.B1 Rpl backup already exist. Processing file: rm340__05.61.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 10.70 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:DA3BDA66 Area [01000000-0101FFFF] erased in 0.437 s Area [01020000-01C3FFFF] erased in 38.672 s Flash programming ... Programming completed in 5 min 58.032 s File Processed in 6 min 54.797 s Processing file: rm340__05.61.image_ac as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.25 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:DA3BDA66 Area [02000000-02DBFFFF] erased in 1 min 26.765 s Area [02DC0000-02F9FFFF] erased in 11.750 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 29.390 s Content extract fail, continue anyway ... File Processed in 3 min 48.391 s Processing file: rm340__05.61.ppm_ac as PPM [DCT4,DCT4 ALGORITHM] size: 2.54 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0091DFCF:DA3BDA66 Area [01C40000-01FFFFFF] erased in 12.360 s Flash programming ... Programming completed in 1 min 16.922 s File Processed in 1 min 45.140 s Flashing completed in 12 min 56.562 s Phone not responding ! Total time to process is 19 min 5.218 s |
10-09-2009, 09:54 | #15 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1077162 Status: Offline Thanks Meter: 171 | yesterday I have problem also flashing with wd2 phones in new update also in dct3 by flashing with files of roles backup .fls in dct3 problem is incountering erase error and write address but BB5 PHONES ARE WORKING GOOD YESTERDAY AND TODAY I hope you will resolve this small bugs from it. |
The best version for flashing and downgrade 3.2 rev 5.4 with UFS!!! | gprsman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-17-2010 20:02 |
how to get back to 3.2 rev 5.6 from 3.3 | Arjun mishra | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-27-2009 11:00 |
how to get back to 3.2 rev 5.6 from 3.3 ??? | gyuszko | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-23-2009 16:37 |
Flashing error on mxkey to 3.2 rev 5.6 | archi3 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 11-07-2009 22:00 |
MobiEX 3.2 rev. 5.2 Unlocking DCT4+ RM-298, RM-340 n RH-112 | abellcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-09-2009 07:30 |
