Old 10-07-2012, 12:44   #1 (permalink)
Member: 1820659
mobileEX v3.5 rev 2.3 ERROR
Hi to all, i had recently synchronized the files in mobileEx software and connected a nokia mobile(any model) through HTI box. when trying to scan the mobile is displaying at the bottom "pooling... no response from the phone".. Can anyone suggest solution...
Old 10-07-2012, 16:47   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
are sure type of phone like bb5 dct-4 OR xgold confirm your selection.
BR.
Arsalan gsm2000.
Old 10-08-2012, 13:48   #3 (permalink)
Member: 1820659
both DCT4 and BB5 connected with f-bus flashing cable through HTI are not working.. see the attached pic for further reference and the type of error....
Old 10-08-2012, 13:50   #4 (permalink)
Member: 1820659
BR.
Arsalan gsm2000.
seee the both pics for further reference... type of error etc.. thnx for rply...
Old 10-08-2012, 14:02   #5 (permalink)
Member: 1820659
BR.
Arsalan gsm2000.
while performing scan error is: no response from the phone(1st pic)
while performing bus check the error is: shown in 2nd picture..
Old 10-08-2012, 18:01   #6 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Follow this screen shots.
BR.
Arsalan gsm2000.
Old 10-09-2012, 11:15   #7 (permalink)
Member: 719527
Thanks Meter: 8
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C084B46F
Using device: HTI, FW ver: 00.50, SN: 00003437
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 08F0010C51627E56FDF13C725B58FCA80C7B5FA0
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
ERROR: Packet Error(0xAA), code 0xC1000003
Old 10-09-2012, 13:37   #8 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
go to settings>config>untick new protocol baseband.
BR.
Arsalan gsm2000.
Old 10-10-2012, 06:28   #9 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Please HELP !!
I have a same problem and I not get solution from support !
After the last update not work any more
Old 10-10-2012, 06:39   #10 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Please HELP !!
Old 10-12-2012, 15:10   #11 (permalink)
Member: 1820659
Yeah, doing the same But...!
BR.
Arsalan gsm2000.
Using the same thing but not working
For nokia devices using BB5, but no use... What to do?
Old 10-12-2012, 15:12   #12 (permalink)
Member: 1820659
Originally Posted by Dany View Post
Please HELP !!
Do u got any solution for that? If u get a solution then inform to me also...
Old 10-12-2012, 15:20   #13 (permalink)
Member: 77002
Sonork: 100.1657194
Thanks Meter: 79
Hi RaviYP,
No bro, I not have any solution for this problem. I make the same that the picture said and also change the transistor but the problem continued.
Before update the HTI and syncronize files my box work well but after no boot any more.
I said to you the same, if you get solution...please advise to me urgent !
The support cant give me good solution.
Regards,
Old 10-12-2012, 15:43   #14 (permalink)
Member: 1820659
for sure
Hi RaviYP,
Regards,
i will inform u if i find a solution. same on ur part tooo
Thanks...
The Following User Says Thank You to Ravi YP For This Useful Post:
Old 10-16-2012, 16:00   #15 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Friends,
There are some Solutions to Resolve this Issue,
Check it out here: http://forum.gsmhosting.com/vbb/f550...5/#post8849181
Synchronize File & Update HTI once again.
BR,
ZUBER
Page generated in 0.24527 seconds with 10 queries
