mobileEX v3.5 rev 2.3 Problem Hi, I make other post about this problem with this new update. (Green Box) Before installed this update the sw work well but now always get this error when Check Flashing Bus I get this problem with many models. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxA Using device: HTI, FW ver: 00.50, SN: 0000xxxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1590000275A30052FBAE5CED3B9E096A8A1C7C22 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW ERROR: Packet Error(0xAA), code 0xC1000003 Thanks For Help br |
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C084B46F Using device: HTI, FW ver: 00.50, SN: 00003437 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 08F0010C51627E56FDF13C725B58FCA80C7B5FA0 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD ERROR: Packet Error(0xAA), code 0xC1000003 |
plese salotion do [][][][[ |
http://imageshack.us/a/img809/7912/loaderb.jpg BR. Arsalan gsm2000. |
Hi, Its configurated as the same as your pic bro, but the error persist :mad: br, |
Support can help me please ? I cant work ! :mad: Thanks |
Thanks Support for your fast reply |
Hi, The problem continued :mad: I change the transistor but its the same. After last update I get this problem. PLEASE support help me !!! many thanks |
Some of the Solutions to come out that. BR, ZUBER |
The problem continued... No solution yet help please |
is the old problem, you need to change the hti box. ( manole change for free all box with this prolem) or the problem is only your rj-45 @zuber why you are put the photo in the avatar¿? is a litlle tatty.. no?¿ this is not professional... need to do screenshots signeds by_zuber :)))))) |
