03-31-2010, 11:57 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh Age: 44
Member: 1025487 Status: Offline Thanks Meter: 64 | mobileEx_setup_v3[1].3_rev1.7_fixed-no dct4 Bus check & flashing mobile-Ex team i use mobileEx_setup_v3[1].3_rev1.7_fixed this soft. This soft bb5 program & flashing is 100% ok, but dct4/ dct4+ is not show bus check. so plz help what r i doing now. now i removed 1.7 verson then use 1.6................. plz help.... |
The Following User Says Thank You to naheed_gsm For This Useful Post: |
04-01-2010, 20:35 | #5 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1256230 Status: Offline Thanks Meter: 4 | Data Package Directory --C:\Program Files\Nokia\Phoenix\Products it's working ok...DCT4+ 1208 Bus Check Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000********* ASIC type: 11 UEM Imei: 35862********* Flash Imei: 35826******* MasterCode: 5416465570 RPL saved to "C:\mobileEx\3.3\data\backup\35862*******_BACK.rpl " Phone Type: RH-105 SW Version: V 5.23 10-03-08 RH-105 (c) NMP Imei plain: 358626********** Product Code: 0550547 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EK Language Pack: - not available. Imei net: 35862********** Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
04-02-2010, 16:27 | #7 (permalink) | |
Member: 1256230 Status: Offline Thanks Meter: 4 | Quote:
any way for those who are really intrested in this thread ,mentioned numbers ******* could be anything(everybody can use a text editor) ,important thing here is DCT4/4+ BUS CHECK works.Don't have to take my edited log for it , you all have what you need a phone +cable + Mxkey to see for yourself. nothing is as easy as it seems ,if it's not working try again....good luck everybody Last edited by vitaminc1; 04-02-2010 at 16:36. | |
kc550 after flash dead | masih455 | Octopus LG/Octoplus LG | 7 | 04-03-2010 14:18 |
How to know what cridit & rpl store in my mx key?? | Shantobhai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 12:43 |
Socket error (10065): No route to host | neokia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-31-2010 10:19 |
