Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 10-11-2012, 08:58   #1 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
mobole EX v3.5 rev2.3 not Boot DCT4
This phone is 100% good and working but MX box not Boot
MX team, Please solved the problem
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxxxxx
Using device: HTI, FW ver: 00.50, SN:xxxxxxxxx
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Boot error: CC CC CC 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Old 10-11-2012, 09:04   #2 (permalink)
Teknotel-GSM's Avatar
Member: 917368
Sonork: 1615575
Thanks Meter: 147
DCT4 & DCT3 Always Problem Not Flashing on MxBox
Old 10-12-2012, 18:24   #3 (permalink)
Member: 579284
Thanks Meter: 6
check cable
1st check cable
then
upgrade your HTI firmware
Old 10-12-2012, 18:28   #4 (permalink)
Hamidshah07's Avatar
Member: 504906
Sonork: 1604032
Thanks Meter: 141
Not working with this @dipok , i always face problem with mx key...but on thing with windows 7 mxkey working best.....
Old 10-12-2012, 18:34   #5 (permalink)
Member: 1089712
Thanks Meter: 25
Using device: HTI, FW ver: 00.50, SN: xxxxxxxx
Connection status: EHCI:HUB:HUB:HUB:HUB:USB 2.00 (Full-speed)
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 001943ACA3BDA66
ASIC type: 11
UEM Imei: 35416202576364
Flash Imei: 35416202576364
RPL saved to "E:\mobileEx\3.5\data\backup\RPL\35416202576364_BA CK.rpl"
Processing MCU file: rm305_05.910
[DCT4,DCT4 ALGORITHM] size: 2.34 MB
Supported Ids: 2292
UEM ID: 001943AC:2984DA60
Area [01000000-0100FFFF] erased in 0.969 s
Area [01010000-0179FFFF] erased in 47.750 s
Area [017A0000-017EFFFF] erased in 2.531 s
Area [01F00000-01FDFFFF] erased in 6.735 s
Flash programming ...
Programming completed in 1 min 16.313 s
Old 10-13-2012, 07:56   #6 (permalink)
nathan111284's Avatar
Member: 1370010
Thanks Meter: 57
nice feedback but working fine with me....
Old 10-13-2012, 14:28   #7 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Always select Correct boot loader.
BR.
Arsalan gsm2000.
The Following 2 Users Say Thank You to .::MASTER ALONE::. For This Useful Post:
Page generated in 0.22551 seconds with 8 queries
