08-03-2010, 22:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Mr manole,please if you dont help i am in a hot soup. FLASH,IT GAVE ME ERROR MESSAGE.AFTER FLASHING THE PHONE FAILED.I TRIED TO WRITE RPL AND IT GAVE ME THIS LOG Imei: 35422503140016 Restoring RF/BB DATA from backup ... Error unable to detect product ! Updating WARRANTY ...error 0x0 Updating PROD ...error 0x0 Updating BT ...error 0x0 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1630020EA6DA0158F64A46165A406404560A35CF ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Programming Status: [NAND ERROR: 00060E4E5043000000000000000000Certificate programmed successfully ! THIS IS THE 3RD TIME THIS IS HAPPENING TO ME.THE OTHER TWO PHONES ARE STILL LYING DOWN WAITING.I DONT KNOW WHAT TO DO ON THIS BECAUSE IT IS A COSTLY PHONE AND I CANNOT AFFORD TO PAY. PLEASE WHAT SHOULD I DO.EVERY BODY PLEASE HELP. WHEN I TRY BUSCHECKING THIS IS WHERE IT STOPS Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1630020EA6DA0158F64A46165A406404560A35CF ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Original Imei: 00000000000000 Original Product code: PLEASE HELP |
08-04-2010, 05:43 | #2 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Pls mr manole,you remain the only solution to this problem.you read this post and did not respond to it,rather you responded to the post next to mine.i am still waiting.thanks |
08-04-2010, 07:05 | #3 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 122712 Status: Offline Thanks Meter: 121 | @austinejjasa hi try usb dead flashing methods.. if your problem still not help remove the file mobileEX.xml or just rename it do sign application again then try fullflashing again using fbus interface mode. if you still not helped with this solutions use another interface mode like, jaf, mtbox, atf, ufs |
08-04-2010, 07:12 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | because your phone can't entering LOCAL/TEST mode, 1.check FBUS cable , make sure have good connection and good BSI VALUE . 2.try reflashing with USB with lastest firmware version ( as CxVj said ) br, |
