Old 02-16-2010, 16:32   #1 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Mr.Manole Sir Pls Help me
hello everybody i hav 3600s nokia whn power on after 2 min automatically Off. here is log pls check . and reply with solution
Phone Type: RM-352 (Nokia 3600s)
SW Version: V 07.23 17-07-09 RM-352 (c) Nokia
Imei plain: 355706---------------
Product Code: 0557810
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
"C:\Program Files\Nokia\Phoenix\Products\RM-352" folder created.
Imei net: 35570------------
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-16-2010, 16:38   #2 (permalink)
Member: 762819
Thanks Meter: 232
Dear! You must Super SD Auth only. Everything will be alright. Tested by me. Worked 100%
Old 02-16-2010, 16:42   #3 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Bro can u Upload perfect PM file for 3600s
Old 02-16-2010, 16:55   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
do selftest and paste here.
br,
Old 02-16-2010, 17:21   #5 (permalink)
Member: 1086393
Thanks Meter: 771
Hv you flashed the phone? flashed &post here
Old 02-17-2010, 06:23   #6 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Need Pm file for 3600s
Old 02-17-2010, 07:37   #7 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
here is self test pls check and tell me whts the solution ?
Phone Type: RM-352
SW version: V 07.23 17-07-09 RM-352 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
15 SLEEP_X_LOOP Y PASSED(00)
46 UEM_CBUS_IF Y PASSED(00)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
22 CAMERA_IF N !NOT EXECUTED(03)
43 LCD N !NOT EXECUTED(03)
21 LPRF_IF N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
42 RADIO Y !FAILED(01)
69 BACKLIGHT Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
71 BT_WAKEUP N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
88 TAHVOINT Y PASSED(00)
101 BTEMP N !NOT EXECUTED(03)
115 TVOUT_IF N !NOT EXECUTED(03)
119 IIC N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03)
128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Old 02-17-2010, 15:28   #8 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
Whr is Manole sir pls help me for ths 3600s automatically off after 2 min
Old 02-17-2010, 16:08   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
like HW issue,
go to hardware side, and check that.
br,
2626 hang and power off.sir pls help me VIBINDAS_INDIA Nokia Hardware & Hardware Repair 4 06-24-2008 11:57
sir pls help me what problem is this cgsm Infinity-Box 8 05-25-2008 08:24
hi sir pls help me Rudrax Infinity-Box 2 05-09-2007 19:32
sir pls help me angeltom Nokia Multimedia 2 04-20-2007 20:58
Page generated in 0.17312 seconds with 10 queries
