Old 07-16-2009, 16:56   #1 (permalink)
reaz.com's Avatar
Member: 310155
Thanks Meter: 1,304
MT cant write PM with SX4 !! but MX-Key succesfully write PM with SX4 !!!
now problem solved.
THANKS MX team !!!
here is log of MT-Box..................
Phone is in: Local mode
Model: RM-84 ( N70)
V 05wk07v48.1/28-08-07/RM-84 (c) Nokia.
Production serial number CTD440399
Product code 0547341
Module code
Basic production code 0522156
Flash code
Order number
Long production SN
MCU SW V 05wk07v48.1/28-08-07/RM-84/(c) Nokia.
HW 7003
PCI
RFIC 150a160f
DSP rolf_05wk07v29p1
LCD 2728220
APE SW Core V 5.0737.3.0.1/13-09-07/RM-84/(C)Nokia
APE Variant V 5.0737.3.0.1-05.01/13-09-07/RM-84/(c)Nokia.
Retu 32
Tahvo 53
APE HW 256
APE ADSP SW 16054
IMEI: 355521017245842
WARNING: VPP pin is not connected, disabling VPP.
Failed to locate SX4 on PC. Connecting server
Connect...
Login...
busy, waiting...
Connect...
Login...
busy, waiting...
PMM Authorize SUCCESSFULL
Sending to phone Resource: 01
Warning: Failed to write 001:0001, 4bytes.
Use SX4 button to authorize
Warning: Failed to write 001:0002, 86bytes.
Warning: Failed to write 001:0004, 110bytes.
Warning: Failed to write 001:0005, 4bytes.
Warning: Failed to write 001:0006, 86bytes.
Warning: Failed to write 001:0008, 110bytes.
Warning: Failed to write 001:000D, 86bytes.
Warning: Failed to write 001:000F, 4bytes.
Warning: Failed to write 001:0010, 86bytes.
Warning: Failed to write 001:0012, 86bytes.
Warning: Failed to write 001:0014, 86bytes.
Warning: Failed to write 001:0016, 16bytes.
Warning: Failed to write 001:0017, 4bytes.
Warning: Failed to write 001:0018, 84bytes.
Warning: Failed to write 001:0019, 16bytes.
Warning: Failed to write 001:001D, 6bytes.
here is log of MX-Key..................
Version Info:
MCU SW version:  V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
HW version:  7003
RFIC version:   150a160f
DSP version:   rolf_05wk07v29p1
Retu version:  32
Tahvo version:  53
Product Info:
Production serial number:  CTD440399
Product code:  0547341
Basic production code:  0522156
Serial Numbers:
IMEI plain:  355521017245842
IMEI spare to net:  3A 55 25 01 71 42 85 04
IMEI SV to net:  33 55 25 01 71 42 85 14 F2
Other Info:
Model :  Nokia N70 (Imaging Phone)
CS type :  GSM900/GSM1800/GSM1900
Project Name:  Rolf 3G
HW Details:
RAP:  RAP v2.21E PA-4377183
OMAP:  OMAP 1710-4377049
RETU:  RETU v3.02-4396177
TAHVO:  TAHVO v5.2 LF-4376533
RF:  HINKU v3.10A + VINKU v3.14A-4380039 + 4380041
BSI: 0.1 KOhm
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN, DATA=23420F
BLOCK 2:   1=OPEN, DATA=23594F
BLOCK 3:   1=OPEN, DATA=23420F
BLOCK 4:   1=OPEN, DATA=23594F
Scanning local SX4 Card ...
No SX4 Card found.
Connecting to server ...MXKEY-SERVER v2.3 hello 202.134.14.6
SUPERDONGLE auth succeeded!
Writing PM from Node ...
Section: 1
 - Key: 0, size 114 bytes written.
Warning: failed to write 1 - 1 (4 bytes)
Warning: failed to write 1 - 2 (86 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 5 (4 bytes)
Warning: failed to write 1 - 6 (86 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (86 bytes)
Warning: failed to write 1 - 15 (4 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (16 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Section: 2
 - Key: 0, size 340 bytes written.
Section: 4
 - Key: 1, size 16 bytes written.
 - Key: 2, size 44 bytes written.
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 9, size 5 bytes written.
Section: 8
 - Key: 0, size 12 bytes written.
 - Key: 1, size 12 bytes written.
 - Key: 6, size 4 bytes written.
 - Key: 7, size 8 bytes written.
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
 - Key: 5, size 6 bytes written.
 - Key: 7, size 2 bytes written.
 - Key: 8, size 2 bytes written.
 - Key: 9, size 2 bytes written.
 - Key: 10, size 2 bytes written.
 - Key: 11, size 2 bytes written.
 - Key: 19, size 2 bytes written.
 - Key: 20, size 2 bytes written.
 - Key: 23, size 4 bytes written.
 - Key: 24, size 4 bytes written.
 - Key: 25, size 2 bytes written.
 - Key: 26, size 2 bytes written.
 - Key: 27, size 2 bytes written.
 - Key: 28, size 2 bytes written.
 - Key: 38, size 2 bytes written.
 - Key: 39, size 2 bytes written.
 - Key: 40, size 2 bytes written.
 - Key: 41, size 2 bytes written.
 - Key: 42, size 2 bytes written.
 - Key: 43, size 4 bytes written.
 - Key: 44, size 4 bytes written.
 - Key: 45, size 4 bytes written.
 - Key: 47, size 16 bytes written.
 - Key: 48, size 2 bytes written.
 - Key: 49, size 2 bytes written.
 - Key: 50, size 20 bytes written.
 - Key: 51, size 10 bytes written.
 - Key: 52, size 2 bytes written.
 - Key: 53, size 20 bytes written.
 - Key: 54, size 10 bytes written.
 - Key: 66, size 2 bytes written.
 - Key: 67, size 2 bytes written.
 - Key: 68, size 2 bytes written.
 - Key: 69, size 2 bytes written.
 - Key: 70, size 2 bytes written.
 - Key: 71, size 2 bytes written.
 - Key: 72, size 2 bytes written.
 - Key: 73, size 2 bytes written.
 - Key: 74, size 2 bytes written.
 - Key: 75, size 2 bytes written.
 - Key: 76, size 2 bytes written.
 - Key: 77, size 2 bytes written.
 - Key: 78, size 2 bytes written.
 - Key: 79, size 2 bytes written.
 - Key: 80, size 2 bytes written.
 - Key: 81, size 2 bytes written.
 - Key: 82, size 2 bytes written.
 - Key: 83, size 2 bytes written.
 - Key: 84, size 2 bytes written.
 - Key: 85, size 2 bytes written.
 - Key: 86, size 2 bytes written.
 - Key: 87, size 2 bytes written.
 - Key: 88, size 2 bytes written.
 - Key: 89, size 2 bytes written.
 - Key: 90, size 2 bytes written.
 - Key: 91, size 2 bytes written.
 - Key: 92, size 2 bytes written.
 - Key: 93, size 2 bytes written.
 - Key: 94, size 2 bytes written.
 - Key: 95, size 2 bytes written.
 - Key: 96, size 2 bytes written.
 - Key: 97, size 2 bytes written.
 - Key: 98, size 2 bytes written.
 - Key: 99, size 2 bytes written.
 - Key: 100, size 2 bytes written.
 - Key: 101, size 2 bytes written.
 - Key: 102, size 2 bytes written.
 - Key: 103, size 2 bytes written.
 - Key: 104, size 2 bytes written.
 - Key: 105, size 2 bytes written.
 - Key: 106, size 2 bytes written.
 - Key: 107, size 2 bytes written.
 - Key: 108, size 4 bytes written.
 - Key: 109, size 4 bytes written.
 - Key: 111, size 4 bytes written.
 - Key: 112, size 4 bytes written.
 - Key: 113, size 4 bytes written.
 - Key: 114, size 4 bytes written.
 - Key: 115, size 16 bytes written.
 - Key: 116, size 4 bytes written.
 - Key: 117, size 2 bytes written.
 - Key: 118, size 2 bytes written.
 - Key: 119, size 859 bytes written.
Section: 17
Warning: failed to write 17 - 0 (4 bytes)
Section: 25
 - Key: 0, size 64 bytes written.
Section: 26
 - Key: 0, size 16 bytes written.
 - Key: 1, size 32 bytes written.
 - Key: 2, size 68 bytes written.
 - Key: 3, size 6 bytes written.
Section: 27
 - Key: 0, size 15 bytes written.
Section: 29
 - Key: 0, size 6 bytes written.
Section: 35
 - Key: 0, size 10 bytes written.
Section: 44
Section: 50
 - Key: 0, size 2 bytes written.
Section: 54
 - Key: 2, size 24 bytes written.
Section: 88
 - Key: 0, size 36 bytes written.
Section: 92
Section: 94
 - Key: 0, size 40 bytes written.
Section: 95
Section: 96
 - Key: 0, size 24 bytes written.
Section: 107
 - Key: 0, size 21 bytes written.
 - Key: 1, size 79 bytes written.
 - Key: 2, size 79 bytes written.
 - Key: 3, size 70 bytes written.
 - Key: 24, size 88 bytes written.
 - Key: 25, size 132 bytes written.
Section: 117
 - Key: 1, size 3 bytes written.
 - Key: 2, size 6 bytes written.
 - Key: 4, size 9 bytes written.
 - Key: 5, size 10 bytes written.
 - Key: 6, size 8 bytes written.
 - Key: 13, size 3 bytes written.
 - Key: 14, size 3 bytes written.
Section: 118
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
Section: 212
Section: 217
Warning: failed to write 217 - 0 (32 bytes)
Section: 239
Section: 248
Warning: failed to write 248 - 0 (120 bytes)
Section: 307
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Completed in 15.172 s
The Following 9 Users Say Thank You to reaz.com For This Useful Post:
Old 07-16-2009, 18:26   #2 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
very good job sir.. i also use both softwares, i know mx key is best
Old 07-16-2009, 18:36   #3 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,950
Is not the best, but there are some features we offer and can use only with MXKEY and customers are happy with this.
And is cheapest Nokia Flasher in Market right now
BR,
Manole
The Following 11 Users Say Thank You to MANOLE For This Useful Post:
Old 07-17-2009, 02:05   #4 (permalink)
amar22ado's Avatar
Member: 230087
Thanks Meter: 370
BR,
Manole
yes your right................... indeed
Old 07-17-2009, 06:58   #5 (permalink)
Member: 278546
Thanks Meter: 142
why u comparing mx key with mt box, mt box is from great team , mx key team waiting for jaf updates to release new update
Old 07-17-2009, 09:16   #6 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 899
Bro then MT box waiting for which box bcoz till now MXkey n MT box have the same solutions n function even mxkey doing best in SX4 Auth n MT fails,,,
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 07-17-2009, 14:30   #7 (permalink)
Member: 278546
Thanks Meter: 142
how u decided mt fails in sx4 ? and no sim lock damages even show error when writing pm with sx4, do you damaged any simlock with mt?
Old 07-17-2009, 14:54   #8 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
but i have try many times write pm with sx4 ..
always show me error .. whats the problem.. i will post log in future..and any buddy have video tutorial then please share with us
Old 07-17-2009, 17:09   #9 (permalink)
Member: 214340
Thanks Meter: 899
If u can not see in the forum ragarding complain agasint Mt box sx4 auth the u must open ur eyes n confess all that,,,I did not n will never use mt box bcoz mxkey has all such powerfull functions n doing gr8 job,,,
Regards.
Old 07-17-2009, 20:39   #10 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
mxkey is realy great tool , for bb5 just use scan all info shows important is superdongle key is valid or not no other box is having such feature
keep it up thanks to Alim
Old 07-18-2009, 06:37   #11 (permalink)
Member: 278546
Thanks Meter: 142
Regards.
mt box little hard to use see videos and use mt box , because, mt box is different when compare with jaf and mxkey, so u need to learn how to use mt box ...
MX-KEY succesfully SD repair post here Code:L.A 22 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-03-2010 15:22
BlackBerry 8520 Curve Read MEP 2,3 & 4 Code Done But MX-Key Not Done .:Towhid:. FuriousGold 8 02-02-2010 11:57
mx-key not write rpl amanhalwara MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-25-2010 07:49
Video .. Repair SL And SX4 By Mx-Key Farrass MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 08-06-2009 19:19
help how to use sx4???? on mx key mawan161080 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 06-26-2009 19:47
Page generated in 0.43907 seconds with 8 queries
