Old 09-30-2009, 09:31   #1 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
Question mx cannot unlock 5800...?
hi
i m trying to unlock 5800 with mx.
but all time faceimg that problem.here is log
Imei: xxxxxxxxxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Vodafone, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2341500000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F
BLOCK 2: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F
Backup already exist.
Using device: J.A.F, FW ver: 01.B1
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot(0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x190C bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending Certificate(0x1A20 bytes) ...OK
Calculating NCK using security server ...
Connecting to server[host1.nkrpl.biz] ...OK, Login ...
Sending NCK code ...
Reading Simlock info ..
no responce from phone.
Old 09-30-2009, 12:41   #2 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
try with ufs interface
and post some more info about ur phone version
wbr
Old 10-01-2009, 09:30   #3 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
phone version is 21.01
Old 10-01-2009, 11:45   #4 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,678
Use UFS interface your problem will be solve
The Following User Says Thank You to GsmEasy For This Useful Post:
Old 10-20-2009, 16:21   #5 (permalink)
Member: 772286
Thanks Meter: 25
5800 V 20.2.014
Imei: 359348*********
Provider: Tim, Country: Brazil
Counter: 0/3, 0/10
CONFIG_DATA: 7240200000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F
BLOCK 2: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F
BLOCK 3: 1=LOCKED (MCC+MNC): 72402F, DATA=72402F
BLOCK 4: 1=LOCKED (MCC+MNC): 72403F, DATA=72403F
BLOCK 5: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F
BLOCK 6: 1=LOCKED (MCC+MNC): 72404F, DATA=72404F
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Connecting to server[nkrpl.biz] ...OK, Login ...
Reading Simlock info ...
Counter: 0/3, 0/10
Big Team MX. the one after that update does not support apparatus was supported!
how to unlock 5800 with mx-key himanshu taldar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 07-30-2010 12:31
Mx-key cannot unlock 5800 ver 30,31 ENG. ADETUNJI MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-18-2010 22:16
I cannot unlock 5800 with mxkey! nunu.gabriel MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-16-2010 14:33
Can MX-Key Unlock 5800? BackSlash_cu MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 11-15-2009 12:58
how to unlock 5800/N96 with Mx key? is it possible or not? malikzahidawan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-08-2009 21:12
Page generated in 0.15177 seconds with 9 queries
