11-06-2009, 06:03 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | mx key mobileEx_setup_v3.2_rev5.6 05/11 · v3.2 revision 5.6, Public-Release v3.2 revision 5.6, Public-Release #Minor update - MAIN Added, Application Signing system ~ This is new application security improvement ~ Application will check it signatures when needed, this will check unique card id, application version, and signature datetime validity ~ New created signature will be valid for next 6 month after signing ~ It means that after new update, you might need to 'Sign Application' if the current signature doesnt meet the requirement. ~ Before signing request, sw will set system datetime from ntp server if datetime is not correct. ~ Note: Make sure you have set you computer date,time. ~ The application signing system will not work on the computer with invalid date time ! Removed, Ping on server check Fixed, Windows Vista SP2 compability. - NK Added, BB5 RAPU USB Flashing(spesially for new Flash) Added, Dynamic Camera Configuration upload ~ This features located at 'Phone Test->Camera' Added, TIKU CDMA Product Data (PREPAID_CS_TYPE) fix using server calculation ~ This features will consume credit, how much it will take will be displayed once you logged in using 'Dongle Id' ~ The Service tag is 'DCT4 IMEI+PRODUCT DATA' Added, BB5 RAP3NAND Erase User Area in the 'Quick Fix' tab ~ Usefull to fix BLANK/BLINK or doesnt switch on problem. Added, BB5 PA_SL identification from PASUBTOC Added, New CS type info for newer phone Improved, FAST flash routine ~ SW will keep in flash mode when processing image file, means that it will skip boot and loader upload if config from each file is similiar. Improved, BB5 RPL write ~ SIMLOCK_DATA will be uploaded after NPC write, since new BB5 phone will only accept SIMLOCK_DATA if NPC is valid ! Fixed, BB5 'Security block invalid' bug Added, Detailed information for each 'Quick Fix' function |
[Update] PhoneIdentity For Mx-Key [Init File For MX-KEY] | jubjang | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 01-24-2011 17:43 |
how to buy mx key orginal in india please replay mx key teem | bijugreat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-27-2010 22:08 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
plz halp mx key team 6220c not unlok for mx key | parmodparmod | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 02-16-2010 11:22 |
