Old 02-22-2013, 06:31   #1 (permalink)
Member: 496386
Thanks Meter: 6
Is mx key box *windows 7 sported .
plz tell me Is mx key box *windows 7 sported .
Old 02-22-2013, 06:33   #2 (permalink)
Member: 221592
Sonork: 100.1637963
Thanks Meter: 13
yes bro fully supported in win 7 tested by me
Old 02-23-2013, 07:03   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Post your detail with Screen Shot, if any Problem,
Bcoz Mxkey support all OS.
BR,
ZUBER
Old 02-23-2013, 07:54   #4 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
yes i use 7 now pro is flash ok but can't reset security code
here is flashing log
nokia x2-01 security lock problem pls help..
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086FDE7
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010060CC
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000E86D387574D3F6069E46F5C960EBDE
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 178B764E
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Selected firmware certificate matched.
Original Imei: 35484204861420
Original Product code: 059C3V5
Bluetooth ID: D82A7E437F52
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
[RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
Page generated in 0.15481 seconds with 9 queries
