10-18-2010, 20:32 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Hello Age: 38
Member: 99115 Status: Offline Thanks Meter: 99 | Mx key can`t flash 1202 rh-111 (ANSWERED) SCAN OK Phone Type: RH-111 SW Version: V 4.50 10-10-09 RH-111 (c) NMP Imei plain: 35801*******-* Product Code: 0568573 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 35801103936923 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN SELECT FILES Phone Type: RH-111 TimeStamp: 2009-04-21T02:57:49Z SW Version: 4.33 Variant Version: 001 ProductProfile: RH111_0568573_4.33_001.spr Simlock: 0568573_SimLockDataVerifier_vDCT4.sim Language Pack: - not available. WHEN FLASH OR BUS CHECK Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010) ERROR: could not boot device. |
10-19-2010, 07:06 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | hi bro do u know the prosider of flashing infinioan platform ... first tick on x-gold server then load file as u load normaly then press phone on/off then click on flash .... |
10-19-2010, 07:52 | #6 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | orignal post by @mobile_hotman 06-24-2010, 21:48 I here post the successfull flashing log LOGS: ------ ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755A3BDA66 ASIC type: 11 UEM Imei: 35319603087105 Processing file: rh112_003.000 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming MCU ... rh112_003.000: [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 Area [01000000-0100FFFF] erased in 1.125 s Area [01010000-013AFFFF] erased in 1 min 4.593 s Area [013B0000-013EFFFF] erased in 4.454 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.032 s Flash programming ... Programming completed in 14.797 s File Processed in 1 min 31.734 s Processing file: rh1120_nai03.00ia ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming Content Pack ... rh1120_nai03.00ia: [DCT4,DCT4 ALGORITHM] size: 166.05 KB Supported Ids: 2293 Area [01380000-013AFFFF] erased in 3.312 s Flash programming ... Programming completed in 1.078 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.093 s File Processed in 16.297 s Processing file: rh112_003.00ia ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0013F755:2984DA60 Programming PPM ... rh112_003.00ia: [DCT4,DCT4 ALGORITHM] size: 1.08 MB Supported Ids: 2293 Area [01240000-0124FFFF] erased in 1.109 s Area [01250000-0137FFFF] erased in 21.141 s Flash programming ... Programming completed in 6.969 s File Processed in 34.875 s Flashing completed in 2 min 42.141 s Phone Type: RH-112 (Model = 1202) SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35319603087105-6 Product Code: 0562271 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35319603087105 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 2 min 50.219 s and if u want more logs then visit on http://forum.gsmhosting.com/vbb/archive/t-1031984.html |
10-19-2010, 08:17 | #7 (permalink) | |
Member: 99115 Status: Offline Thanks Meter: 99 | Quote:
Phone Type: RH-112 (Model = 1202) SW Version: V 03.00 14-11-08 RH-112 (c) NMP | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
