07-24-2009, 13:53 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | mx-key can,t unlock 1661-rm122 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! PhoneType:RH-122 SwVersion: V 03.10 11-02-09 RH-122 (c) Nokia MCU file: rh122_003.100 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CF9A4C:2984DA60 Area [01000000-0101FFFF] erased in 1.547 s Area [01160000-0117FFFF] erased in 1.531 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 ASIC ID: 0x2293 [UPPCosto ver: 2.0] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CF9A4C:2984DA60 Area [01000000-0101FFFF] erased in 1.562 s Area [01160000-0117FFFF] erased in 1.532 s Programming ... Programming completed. |
07-24-2009, 14:14 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 777523 Status: Offline Sonork: 100.1584558 Thanks Meter: 335 | hello boss plzz help me. i have a 1661 phone. mcu version 3.70.. this phone is lock. i flash this phone with downgrad version v3.10. but my flash not compleat. so my phone is dead. then i full eares flash . i again flash with v3.70. then flash compleat but now my phone contract service. if i unlock it with mx-key, it say'd Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! if i want downgrad my phone flash not compleat phone was dead now what i do i m very confuse plzz any body help me.. |
09-01-2009, 15:13 | #6 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 293203 Status: Offline Thanks Meter: 12 | i was try to solv thats prob with this steps by mx,here is : end 1200 flashing log : Imei plain is invalid !!! Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! Total time to process is 5 min 28.235 s after that i try to use RPL backup from server by credit,n the log is here : Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008429B1A3BDA66 ASIC type: 11 UEM Imei: 355737020xxxxx-x Connecting to server ...OK, Login ... Hello C08024D0, you have 9900 credits left. RPL saved to "C:\mobileEx\3.2\data\backup\RPL\355737020xxxx x-x.RPL" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-99 SW Version: V 5.91 27-03-09 RH-99 (c) NMP Imei plain: 355737020xxxxx-x Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MD Language Pack: English,Filipino,Vietnamase Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! i think that any problem with the flash chip (yellow font) n the problem about imei and simlock (red font) still same after i try to flashing against by UFS,and all processing is fine from flash writing,pm wr,until sett UI except Simlock , then i flash again by MX and ..... same as...like as... .... but i still hard think about this prob,bro...maybe tomorrow troubleshoot 'll found .... by MXkey n MobileX course think, or maybe...anyones would share successfully tested? thanks before guys .... |
09-01-2009, 17:46 | #8 (permalink) | |
Member: 293203 Status: Offline Thanks Meter: 12 | Quote:
thanks for respons Bro,against here i post about log. This is for MX solutions trying,so dont interupt by other box idea,right? First,SCAN LOG : Phone Type: RH-99 SW Version: V 5.71 12-09-08 RH-99 (c) NMP Imei plain: 355737020XXXXX-X Product Code: 0546876 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MD Language Pack: English,Filipino,Vietnamase TimeStamp: 2008-09-16T03:03:11Z SW Version: 5.71 Variant Version: 001 ProductProfile: RH99_0546876_5.71_001.spr Simlock: 0546876_SimLockDataVerifier_vDCT4.sim Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! 2ND STEP, FLASHING BY V.rh99_05.910 (Not 5.71 ) with Set PC,PP,Reset LT and WR PM After Flash Proccessing ticked.also Save Flash Here The log : Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008429B1A3BDA66 ASIC type: 11 UEM Imei: 355737020XXXXX Warning intetrupted [could not save RPL backup from phone,you want continue?] [yes] Processing file: rh99_05.910 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008429B1:2984DA60 Programming MCU ... FlashImage: rh99_05.910 [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 0.594 s Area [01010000-013AFFFF] erased in 35.109 s Area [013B0000-013EFFFF] erased in 2.469 s Area [017C0000-017EFFFF] erased in 0.047 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 19.578 s File Processed in 1 min 7.000 s Processing file: rh99_05.91ud ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008429B1:2984DA60 Programming Content Pack ... FlashImage: rh99_05.91ud [DCT4,DCT4 ALGORITHM] size: 1.21 MB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 0.578 s Area [01250000-0137FFFF] erased in 11.484 s Flash programming ... Programming completed in 10.484 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 45.438 s Processing file: rh99_05.91md ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008429B1:2984DA60 Programming PPM ... FlashImage: rh99_05.91md [DCT4,DCT4 ALGORITHM] size: 1.19 MB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 0.563 s Area [01250000-0137FFFF] erased in 11.500 s Flash programming ... Programming completed in 10.218 s File Processed in 28.187 s Flashing completed in 4 min 58.172 s After Flash Processing ... Updating Product Code OK. Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Uploading Product Profile Decompressing RH99_0546876_5.71_001.spr to C:\PROGRA1\Nokia\Phoenix\Products\rh-99\RH99_0546876_5.71_001\ ...OK Failed! Uploading PM Writing PMM C:\Program Files\Nokia\Phoenix\Products\rh-99\1200.pm Range: 1 - 254 Section: 1, 7 key(s) - Key: 0, size 120 bytes written. - Key: 1, size 426 bytes written. - Key: 2, size 42 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 42 bytes written. - Key: 12, size 2 bytes written. - Key: 16, size 2 bytes written. Section: 2, 1 key(s) - Key: 0, size 424 bytes written. Section: 3, 1 key(s) - Key: 0, size 2 bytes written. Section: 4, 8 key(s) - Key: 0, size 1 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 5, 1 key(s) - Key: 0, size 78 bytes written. Section: 7, 3 key(s) - Key: 0, size 4 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 4 bytes written. Section: 8, 1 key(s) - Key: 0, size 12 bytes written. Section: 11, 115 key(s) - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 8 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 4 bytes written. - Key: 31, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 33, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 35, size 4 bytes written. - Key: 36, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 4 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 1 bytes written. - Key: 43, size 1 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 4 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 4 bytes written. - Key: 50, size 4 bytes written. - Key: 51, size 4 bytes written. - Key: 52, size 4 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 4 bytes written. - Key: 56, size 4 bytes written. - Key: 57, size 4 bytes written. - Key: 58, size 4 bytes written. - Key: 59, size 4 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 4 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 4 bytes written. - Key: 76, size 4 bytes written. - Key: 77, size 4 bytes written. - Key: 78, size 4 bytes written. - Key: 79, size 4 bytes written. - Key: 80, size 4 bytes written. - Key: 81, size 4 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 4 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 1 bytes written. - Key: 86, size 16 bytes written. - Key: 87, size 88 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 2 bytes written. - Key: 110, size 2 bytes written. - Key: 111, size 2 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 2 bytes written. - Key: 114, size 2 bytes written. Section: 12, 1 key(s) - Key: 0, size 2 bytes written. Section: 13, 200 key(s) - Key: 0, size 70 bytes written. - Key: 1, size 70 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 5, size 70 bytes written. - Key: 6, size 70 bytes written. - Key: 7, size 70 bytes written. - Key: 8, size 70 bytes written. - Key: 9, size 70 bytes written. - Key: 10, size 70 bytes written. - Key: 11, size 70 bytes written. - Key: 12, size 70 bytes written. - Key: 13, size 70 bytes written. - Key: 14, size 70 bytes written. - Key: 15, size 70 bytes written. - Key: 16, size 70 bytes written. - Key: 17, size 70 bytes written. - Key: 18, size 70 bytes written. - Key: 19, size 70 bytes written. - Key: 20, size 70 bytes written. - Key: 21, size 70 bytes written. - Key: 22, size 70 bytes written. - Key: 23, size 70 bytes written. - Key: 24, size 70 bytes written. - Key: 25, size 70 bytes written. - Key: 26, size 70 bytes written. - Key: 27, size 70 bytes written. - Key: 28, size 70 bytes written. - Key: 29, size 70 bytes written. - Key: 30, size 70 bytes written. - Key: 31, size 70 bytes written. - Key: 32, size 70 bytes written. - Key: 33, size 70 bytes written. - Key: 34, size 70 bytes written. - Key: 35, size 70 bytes written. - Key: 36, size 70 bytes written. - Key: 37, size 70 bytes written. - Key: 38, size 70 bytes written. - Key: 39, size 70 bytes written. - Key: 40, size 70 bytes written. - Key: 41, size 70 bytes written. - Key: 42, size 70 bytes written. - Key: 43, size 70 bytes written. - Key: 44, size 70 bytes written. - Key: 45, size 70 bytes written. - Key: 46, size 70 bytes written. - Key: 47, size 70 bytes written. - Key: 48, size 70 bytes written. - Key: 49, size 70 bytes written. - Key: 50, size 70 bytes written. - Key: 51, size 70 bytes written. - Key: 52, size 70 bytes written. - Key: 53, size 70 bytes written. - Key: 54, size 70 bytes written. - Key: 55, size 70 bytes written. - Key: 56, size 70 bytes written. - Key: 57, size 70 bytes written. - Key: 58, size 70 bytes written. - Key: 59, size 70 bytes written. - Key: 60, size 70 bytes written. - Key: 61, size 70 bytes written. - Key: 62, size 70 bytes written. - Key: 63, size 70 bytes written. - Key: 64, size 70 bytes written. - Key: 65, size 70 bytes written. - Key: 66, size 70 bytes written. - Key: 67, size 70 bytes written. - Key: 68, size 70 bytes written. - Key: 69, size 70 bytes written. - Key: 70, size 70 bytes written. - Key: 71, size 70 bytes written. - Key: 72, size 70 bytes written. - Key: 73, size 70 bytes written. - Key: 74, size 70 bytes written. - Key: 75, size 70 bytes written. - Key: 76, size 70 bytes written. - Key: 77, size 70 bytes written. - Key: 78, size 70 bytes written. - Key: 79, size 70 bytes written. - Key: 80, size 70 bytes written. - Key: 81, size 70 bytes written. - Key: 82, size 70 bytes written. - Key: 83, size 70 bytes written. - Key: 84, size 70 bytes written. - Key: 85, size 70 bytes written. - Key: 86, size 70 bytes written. - Key: 87, size 70 bytes written. - Key: 88, size 70 bytes written. - Key: 89, size 70 bytes written. - Key: 90, size 70 bytes written. - Key: 91, size 70 bytes written. - Key: 92, size 70 bytes written. - Key: 93, size 70 bytes written. - Key: 94, size 70 bytes written. - Key: 95, size 70 bytes written. - Key: 96, size 70 bytes written. - Key: 97, size 70 bytes written. - Key: 98, size 70 bytes written. - Key: 99, size 70 bytes written. - Key: 100, size 70 bytes written. - Key: 101, size 70 bytes written. - Key: 102, size 70 bytes written. - Key: 103, size 70 bytes written. - Key: 104, size 70 bytes written. - Key: 105, size 70 bytes written. - Key: 106, size 70 bytes written. - Key: 107, size 70 bytes written. - Key: 108, size 70 bytes written. - Key: 109, size 70 bytes written. - Key: 110, size 70 bytes written. - Key: 111, size 70 bytes written. - Key: 112, size 70 bytes written. - Key: 113, size 70 bytes written. - Key: 114, size 70 bytes written. - Key: 115, size 70 bytes written. - Key: 116, size 70 bytes written. - Key: 117, size 70 bytes written. - Key: 118, size 70 bytes written. - Key: 119, size 70 bytes written. - Key: 120, size 70 bytes written. - Key: 121, size 70 bytes written. - Key: 122, size 70 bytes written. - Key: 123, size 70 bytes written. - Key: 124, size 70 bytes written. - Key: 125, size 70 bytes written. - Key: 126, size 70 bytes written. - Key: 127, size 70 bytes written. - Key: 128, size 70 bytes written. - Key: 129, size 70 bytes written. - Key: 130, size 70 bytes written. - Key: 131, size 70 bytes written. - Key: 132, size 70 bytes written. - Key: 133, size 70 bytes written. - Key: 134, size 70 bytes written. - Key: 135, size 70 bytes written. - Key: 136, size 70 bytes written. - Key: 137, size 70 bytes written. - Key: 138, size 70 bytes written. - Key: 139, size 70 bytes written. - Key: 140, size 70 bytes written. - Key: 141, size 70 bytes written. - Key: 142, size 70 bytes written. - Key: 143, size 70 bytes written. - Key: 144, size 70 bytes written. - Key: 145, size 70 bytes written. - Key: 146, size 70 bytes written. - Key: 147, size 70 bytes written. - Key: 148, size 70 bytes written. - Key: 149, size 70 bytes written. - Key: 150, size 70 bytes written. - Key: 151, size 70 bytes written. - Key: 152, size 70 bytes written. - Key: 153, size 70 bytes written. - Key: 154, size 70 bytes written. - Key: 155, size 70 bytes written. - Key: 156, size 70 bytes written. - Key: 157, size 70 bytes written. - Key: 158, size 70 bytes written. - Key: 159, size 70 bytes written. - Key: 160, size 70 bytes written. - Key: 161, size 70 bytes written. - Key: 162, size 70 bytes written. - Key: 163, size 70 bytes written. - Key: 164, size 70 bytes written. - Key: 165, size 70 bytes written. - Key: 166, size 70 bytes written. - Key: 167, size 70 bytes written. - Key: 168, size 70 bytes written. - Key: 169, size 70 bytes written. - Key: 170, size 70 bytes written. - Key: 171, size 70 bytes written. - Key: 172, size 70 bytes written. - Key: 173, size 70 bytes written. - Key: 174, size 70 bytes written. - Key: 175, size 70 bytes written. - Key: 176, size 70 bytes written. - Key: 177, size 70 bytes written. - Key: 178, size 70 bytes written. - Key: 179, size 70 bytes written. - Key: 180, size 70 bytes written. - Key: 181, size 70 bytes written. - Key: 182, size 70 bytes written. - Key: 183, size 70 bytes written. - Key: 184, size 70 bytes written. - Key: 185, size 70 bytes written. - Key: 186, size 70 bytes written. - Key: 187, size 70 bytes written. - Key: 188, size 70 bytes written. - Key: 189, size 70 bytes written. - Key: 190, size 70 bytes written. - Key: 191, size 70 bytes written. - Key: 192, size 70 bytes written. - Key: 193, size 70 bytes written. - Key: 194, size 70 bytes written. - Key: 195, size 70 bytes written. - Key: 196, size 70 bytes written. - Key: 197, size 70 bytes written. - Key: 198, size 70 bytes written. - Key: 199, size 70 bytes written. Section: 14, 20 key(s) - Key: 0, size 73 bytes written. - Key: 1, size 73 bytes written. - Key: 2, size 73 bytes written. - Key: 3, size 73 bytes written. - Key: 4, size 73 bytes written. - Key: 5, size 73 bytes written. - Key: 6, size 73 bytes written. - Key: 7, size 73 bytes written. - Key: 8, size 73 bytes written. - Key: 9, size 73 bytes written. - Key: 10, size 73 bytes written. - Key: 11, size 73 bytes written. - Key: 12, size 73 bytes written. - Key: 13, size 73 bytes written. - Key: 14, size 73 bytes written. - Key: 15, size 73 bytes written. - Key: 16, size 73 bytes written. - Key: 17, size 73 bytes written. - Key: 18, size 73 bytes written. - Key: 19, size 73 bytes written. Section: 15, 10 key(s) - Key: 0, size 73 bytes written. - Key: 1, size 73 bytes written. - Key: 2, size 73 bytes written. - Key: 3, size 73 bytes written. - Key: 4, size 73 bytes written. - Key: 5, size 73 bytes written. - Key: 6, size 73 bytes written. - Key: 7, size 73 bytes written. - Key: 8, size 73 bytes written. - Key: 9, size 73 bytes written. Section: 16, 10 key(s) - Key: 0, size 73 bytes written. - Key: 1, size 73 bytes written. - Key: 2, size 73 bytes written. - Key: 3, size 73 bytes written. - Key: 4, size 73 bytes written. - Key: 5, size 73 bytes written. - Key: 6, size 73 bytes written. - Key: 7, size 73 bytes written. - Key: 8, size 73 bytes written. - Key: 9, size 73 bytes written. Section: 17, 3 key(s) - Key: 0, size 80 bytes written. - Key: 1, size 80 bytes written. - Key: 2, size 80 bytes written. Section: 18, 1 key(s) - Key: 0, size 2056 bytes written. Section: 19, 1 key(s) - Key: 0, size 15 bytes written. Section: 22, 1 key(s) - Key: 0, size 174 bytes written. Section: 26, 30 key(s) - Key: 0, size 302 bytes written. - Key: 1, size 302 bytes written. - Key: 2, size 302 bytes written. - Key: 3, size 302 bytes written. - Key: 4, size 302 bytes written. - Key: 5, size 302 bytes written. - Key: 6, size 302 bytes written. - Key: 7, size 302 bytes written. - Key: 8, size 302 bytes written. - Key: 9, size 302 bytes written. - Key: 10, size 302 bytes written. - Key: 11, size 302 bytes written. - Key: 12, size 302 bytes written. - Key: 13, size 302 bytes written. - Key: 14, size 302 bytes written. - Key: 15, size 302 bytes written. - Key: 16, size 302 bytes written. - Key: 17, size 302 bytes written. - Key: 18, size 302 bytes written. - Key: 19, size 302 bytes written. - Key: 20, size 302 bytes written. - Key: 21, size 302 bytes written. - Key: 22, size 302 bytes written. - Key: 23, size 302 bytes written. - Key: 24, size 302 bytes written. - Key: 25, size 302 bytes written. - Key: 26, size 302 bytes written. - Key: 27, size 302 bytes written. - Key: 28, size 302 bytes written. - Key: 29, size 302 bytes written. Section: 27, 8 key(s) - Key: 0, size 142 bytes written. - Key: 1, size 142 bytes written. - Key: 2, size 142 bytes written. - Key: 3, size 142 bytes written. - Key: 4, size 142 bytes written. - Key: 5, size 142 bytes written. - Key: 6, size 142 bytes written. - Key: 7, size 142 bytes written. Section: 28, 8 key(s) - Key: 0, size 16 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 16 bytes written. - Key: 4, size 16 bytes written. - Key: 5, size 16 bytes written. - Key: 6, size 16 bytes written. - Key: 7, size 16 bytes written. Section: 29, 5 key(s) - Key: 0, size 304 bytes written. - Key: 1, size 304 bytes written. - Key: 2, size 304 bytes written. - Key: 3, size 304 bytes written. - Key: 4, size 304 bytes written. Section: 30, 1 key(s) - Key: 0, size 144 bytes written. Section: 32, 3 key(s) - Key: 0, size 10 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 2 bytes written. Section: 33, 8 key(s) - Key: 6, size 3 bytes written. - Key: 7, size 3 bytes written. - Key: 8, size 3 bytes written. - Key: 9, size 3 bytes written. - Key: 10, size 3 bytes written. - Key: 11, size 3 bytes written. - Key: 12, size 3 bytes written. - Key: 13, size 3 bytes written. Section: 34, 8 key(s) - Key: 0, size 8 bytes written. - Key: 1, size 8 bytes written. - Key: 2, size 8 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. Section: 35, 1 key(s) - Key: 0, size 1 bytes written. Section: 36, 18 key(s) - Key: 0, size 32 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 8, size 120 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 6 bytes written. - Key: 12, size 17 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 38 bytes written. - Key: 15, size 38 bytes written. - Key: 17, size 10 bytes written. - Key: 18, size 6 bytes written. - Key: 20, size 201 bytes written. Section: 37, 1 key(s) - Key: 0, size 1 bytes written. Section: 38, 11 key(s) - Key: 0, size 13 bytes written. - Key: 1, size 13 bytes written. - Key: 2, size 13 bytes written. - Key: 3, size 13 bytes written. - Key: 4, size 13 bytes written. - Key: 5, size 13 bytes written. - Key: 6, size 40 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. Section: 39, 1 key(s) - Key: 0, size 17 bytes written. Section: 40, 8 key(s) - Key: 0, size 6 bytes written. - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 6 bytes written. - Key: 4, size 6 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 6 bytes written. - Key: 7, size 6 bytes written. Section: 41, 1 key(s) - Key: 0, size 10 bytes written. Section: 46, 2 key(s) - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. Section: 50, 1 key(s) - Key: 2, size 1 bytes written. Section: 54, 1 key(s) - Key: 0, size 4 bytes written. Section: 57, 1 key(s) - Key: 0, size 38 bytes written. Section: 60, 1 key(s) - Key: 0, size 8 bytes written. Section: 61, 1 key(s) - Key: 0, size 4 bytes written. Section: 62, 1 key(s) - Key: 0, size 320 bytes written. Section: 66, 1 key(s) - Key: 0, size 4 bytes written. Section: 68, 1 key(s) - Key: 0, size 8 bytes written. Section: 73, 4 key(s) - Key: 0, size 111 bytes written. - Key: 1, size 256 bytes written. - Key: 2, size 192 bytes written. - Key: 3, size 364 bytes written. Section: 74, 1 key(s) - Key: 0, size 3 bytes written. Section: 91, 1 key(s) - Key: 0, size 174 bytes written. Section: 93, 5 key(s) - Key: 0, size 40 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 40 bytes written. - Key: 3, size 40 bytes written. - Key: 4, size 40 bytes written. Section: 100, 1 key(s) - Key: 0, size 2 bytes written. Section: 101, 9 key(s) - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 16, size 40 bytes written. Section: 109, 1 key(s) - Key: 0, size 102 bytes written. Section: 111, 1 key(s) - Key: 0, size 8 bytes written. Section: 239, 45 key(s) - Key: 0, size 16 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 16 bytes written. - Key: 4, size 16 bytes written. - Key: 5, size 16 bytes written. - Key: 6, size 16 bytes written. - Key: 7, size 16 bytes written. - Key: 8, size 16 bytes written. - Key: 9, size 16 bytes written. - Key: 10, size 16 bytes written. - Key: 11, size 16 bytes written. - Key: 12, size 16 bytes written. - Key: 13, size 16 bytes written. - Key: 14, size 16 bytes written. - Key: 15, size 16 bytes written. - Key: 16, size 16 bytes written. - Key: 17, size 16 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 16 bytes written. - Key: 20, size 16 bytes written. - Key: 21, size 16 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 16 bytes written. - Key: 24, size 16 bytes written. - Key: 25, size 16 bytes written. - Key: 26, size 16 bytes written. - Key: 27, size 16 bytes written. - Key: 28, size 16 bytes written. - Key: 29, size 16 bytes written. - Key: 30, size 16 bytes written. - Key: 31, size 16 bytes written. - Key: 32, size 16 bytes written. - Key: 33, size 16 bytes written. - Key: 34, size 16 bytes written. - Key: 35, size 16 bytes written. - Key: 36, size 16 bytes written. - Key: 37, size 16 bytes written. - Key: 38, size 16 bytes written. - Key: 39, size 16 bytes written. - Key: 40, size 16 bytes written. - Key: 41, size 16 bytes written. - Key: 42, size 16 bytes written. - Key: 43, size 16 bytes written. - Key: 44, size 16 bytes written. Section: 254, 1 key(s) Warning: failed to write 254 - 0 (156 bytes) Completed in 16.984 s Phone Type: RH-99 SW Version: V 5.91 27-03-09 RH-99 (c) NMP Imei plain: 355737020XXXXX-X Product Code: 0546861 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MD Language Pack: English,Filipino,Vietnamase Imei net: 00000000000000 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! Total time to process is 5 min 22.047 s Until this,phone still sweety died any verifications think? post please | |
Mx key can unlock new security blackberry phone | brokendreem | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 2 | 02-02-2010 14:55 |
Us of now where the bomb of mx-key on sl3 unlocking,this is a dream can true??? | RCB Telecom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 12-18-2009 05:57 |
MX Key can or can not?? | richiricherd | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-30-2009 20:36 |
Does MX-key can unlock 1202? | junmatrix | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 09-26-2009 10:23 |
mx key can do it | nadeem ahmad | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-12-2009 11:13 |
