12-01-2009, 09:57 | #1 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 364738 Status: Offline Thanks Meter: 4 | MX KEY CANT DETECT MY UFS AND JAF help mx key team help ........... |
The Following User Says Thank You to raycon_24 For This Useful Post: |
12-01-2009, 10:26 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,620 | Might be the problem of Hardware MX Key has two things. 1) Smart Card 2) P-key It might be the problem of P-key. Please try to install in another computer. Still, there is problem, then, plug out the "Smart Card" and put it to another "P-Key" or Box that you have. Download the GIF file and watch out:-- ============================ http://www.MegaShare.com/1649574 Password:- sairam |
12-01-2009, 11:03 | #3 (permalink) |
Member: 364738 Status: Offline Thanks Meter: 4 | smart card and reader is working fine because i have succesfully registerd my mx key and updated it also.. my problem is mx key cant detect any of my ufs and jaf box's... i even tried using it in another computer still the same......now i cant sign my mxkey application because i've use up all my 5 attempts |
12-01-2009, 11:07 | #4 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | ------------------------- new with mobileEx? try re-scan or click on "NO CONNECTiON". Are you sure has been installed driver correctly. Look at device manager, and attach infos here. Make sure USB A-B cable is, ok. do not plug a lot of devices to your computer usb. Last edited by sijibae; 12-01-2009 at 11:13. |
12-01-2009, 11:21 | #7 (permalink) | |
Member: 364738 Status: Offline Thanks Meter: 4 | Quote:
usb cable is fine, i even tried using a brand new usb cable...... im sot sure about the driver though??????? tried un installing ufs usb driver ang install the one that is inside the mobilex folder C:\mobileEx\3.3\data\drivers\ufs\2.4.16.0 still it shows not connected........ | |
12-01-2009, 11:24 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
the file is mobileEx.xml. you can use it anywhere else, no need to sign via server again. a question, what other tool (ftdi based) installed, beside mxkey? br | |
12-02-2009, 07:12 | #12 (permalink) |
Member: 364738 Status: Offline Thanks Meter: 4 | yes its all working........ but whenever i start mobilex it ask for a driver... i choose the driver from C:\mobileEx\3.3\data\drivers\ufs\2.4.16.0 and overwrite the previous driver, but still it cant detect my ufs or jaf...... am i using the write driver? thnx |
12-02-2009, 08:35 | #14 (permalink) |
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | You can report any info after doing these; 1. After you open mobileEx, copy your "Loaded drivers" log here. 2. print into docs/make screenshot of device manager and attach here. 3. Uninstall all driver from uninstaller program. Make sure that you unplug all ftdi/card from computer. 4. Restart and manual delete driver from system if any. 5. Now install one-by-one, firstly ufs driver and then mxkey. Maybe your driver ver ; 3.1.05.0, sorry if i'm wrong... Newer driver ver; 3.4.16.0 |
12-02-2009, 09:30 | #15 (permalink) | |
Member: 364738 Status: Offline Thanks Meter: 4 | did you mean 2.4.16.0 and not 3.4.16.0?........ Quote:
CAN you upload your driver here thnx | |
mx key cant detect interface | adelzouaghi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 04-27-2010 12:19 |
mx-key cant detect my interface box | toptech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-28-2009 21:30 |
Mx-key can't detect my jaf box | khaalsa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-13-2009 17:52 |
MX Key can't detet my UFS | ARC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 32 | 12-12-2009 18:03 |
my mx-key canot detect my ufs-jaf interface | arabie | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-11-2009 04:36 |
