Old 01-27-2010, 09:29   #1 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
mx-key cant be fix bb5 RPL
Imei plain: 35640602440000-3
Product Code: 0543722
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
need good RPL server
Old 01-27-2010, 09:34   #2 (permalink)
jafarH's Avatar
Member: 731839
Thanks Meter: 45
Language Pack:
- not available.
SIMLOCK invalid!
used mt box or ub,ur prob slove with logs
The Following User Says Thank You to jafarH For This Useful Post:
Old 01-27-2010, 09:37   #3 (permalink)
bhuvanele's Avatar
Member: 237210
Thanks Meter: 90
post phone model, if it is not SL3 then it can be repaired without RPL.
The Following User Says Thank You to bhuvanele For This Useful Post:
Old 01-27-2010, 09:53   #4 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
i have n95 8gb and n96 also same rpl problem
Old 01-27-2010, 12:54   #5 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
can fix or not??????????????????????????????????????????????
Old 01-27-2010, 12:56   #6 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 33
Not by MX-KEY but by UB sure.
Old 01-27-2010, 13:00   #7 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
mx can't reapire sd yet
hare all bb5 product code mx-key sx4 pm fixed SECURITY_TEST passed @gopalhot@ gopalhot MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 05-24-2010 07:24
mx key cant flash bb5 now gebicell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 03-12-2010 02:27
Mx key team pls fix thig bug srinibas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-12-2010 09:07
Mx key team plz fix this problem ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-20-2010 17:24
All mx-key team plz fix this bug fast el7areef MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 12-01-2009 16:13
Page generated in 0.17927 seconds with 9 queries
