12-07-2009, 03:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: philippines Age: 55
Member: 883572 Status: Offline Thanks Meter: 63 | 1202 invalid uem why? phone is good Library version: 1.0.0.11472, Date: 27-11-2009 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0051C0EDA3BDA66 ASIC type: 11 UEM Imei: 35321103616849 Flash Imei: 35321103616849 MasterCode: 6056067101 Flash Imei: 35321103616849 MasterCode: 6056067101 RPL saved to "D:\mobileEx\3.3\data\backup\35321103616849_BACK.r pl" Phone Type: RH-112 SW Version: V 03.00 14-11-08 RH-112 (c) NMP Imei plain: 35321103616849-6 Product Code: 0562309 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MD Language Pack: - not available. Imei net: 35321103616849 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. why is ti showing invalid uem? phone is working good just wanted to try if mxkey could read it n creata a backup. cant create rpl backup |
The Following User Says Thank You to ferdie1969 For This Useful Post: |
12-07-2009, 04:29 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | This is not important error bcoz we cannot create rpl backup of "ASIC type: 11" so don't worry and keep working..... |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
12-07-2009, 04:37 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | try to put the set in testmode/local mode manually and rpl can be backedup it may be some minor bug nothing to worry regards, NEIL |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
07-24-2010, 09:09 | #4 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 596251 Status: Offline Thanks Meter: 33 | 1200 Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C523A1A3BDA66 ASIC type: 11 UEM Imei: 3567900239350 Phone Type: RH-99 SW Version: V 6.00 30-09-09 RH-99 (c) NMP Imei plain: 3567900239350 Product Code: 0546860 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 3567900239350 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. |
08-01-2010, 14:16 | #6 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | NOKIA 1202 AFTER 30SEC OFF ANY SOLUTION? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00B69D27A3BDA66 ASIC type: 11 UEM Imei: 35606803686189 Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35606803686189-3 Product Code: 0562271 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35606803686189 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. |
E66 invalid sim but phone is alredy unlock | MUTUAL | Cyclonebox | 16 | 12-01-2009 08:37 |
Which Phone is Good | myvicky | Off Topic Zone | 2 | 12-29-2007 10:09 |
Which Phone is Good | myvicky | Motorola P2k | 2 | 12-21-2007 19:27 |
Which phone is good???please vote | atin_garg2005 | HTC & PDA WM( With Touchscreen) | 5 | 10-31-2006 08:25 |
x400 invalid SIM but phone is unlocked?? | ghosthacker | Panasonic | 7 | 09-08-2005 17:31 |
