Old 02-10-2010, 09:47   #1 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 222
MX-Key EROR while Opening
unexpected error: Access violation at address 00486A24 in module 'mobileEx.exe'. Read of address 00000000
Old 02-10-2010, 09:51   #2 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
un install it (also remove mobileExfolder in c program)
install agian .
Old 02-10-2010, 09:57   #3 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 222
i revise the same procedure but still stuck with same error
Old 02-10-2010, 19:25   #4 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 101
check ur pc date and time is correct
Old 03-10-2010, 06:34   #5 (permalink)
Member: 731116
Sonork: 100.1612132
Thanks Meter: 28
del mobileEx.xml...can ok
Old 03-10-2010, 07:43   #6 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,418
just press sign application button after this error ur problem solve
Old 06-19-2011, 06:45   #7 (permalink)
rana00's Avatar
Member: 997268
Sonork: 100.1661167
Thanks Meter: 109
solution 100% tested me
uninstall antivirus fast on your pc
uninstall mobileEx -delete folder mobileEx from c \driver
restart pc
setup mobileEx
Old 06-19-2011, 06:50   #8 (permalink)
33872's Avatar
Member: 442421
Thanks Meter: 68
Question
i have same problem old version is ok new version this error
Old 06-19-2011, 06:56   #9 (permalink)
33872's Avatar
Member: 442421
Thanks Meter: 68
restart pc
setup mobileEx
this method problem solved but i attach hwk box then same error no full solution
Old 06-19-2011, 08:18   #10 (permalink)
rana00's Avatar
Member: 997268
Sonork: 100.1661167
Thanks Meter: 109
if same please use mobileEx_setup_v3.4_rev1.9(20110301)
mx key does not open !!! yasser07 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-09-2010 18:31
mx key does not open alansousa MXKEY Nokia Flasher and Unlocker (by Alim Hape) 18 01-20-2010 13:49
mx-key Interface not open show this erore aukonline MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 12-07-2009 19:23
Mx Key exe Not Opening CMT.EROR MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 10-20-2009 18:22
Page generated in 0.37079 seconds with 8 queries
