Old 04-05-2011, 12:25   #1 (permalink)
Member: 732119
Thanks Meter: 64
Mx Key Experts Help Me Out
Nokia 2690 Flashing Error
This Is BUS Check Log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1C40020FDF7601563E0298A3FF2F5596686F2799
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400  - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 1.40.0 revision: 0.0 size: 0x22C10
 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
This Is Flashing Log
Processing MCU file: rm635__10.10.mcusw
[BB5,BB5 ALGORITHM] size: 17.99 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.094 s
CMT NOR area [000006C0-0001FFFF] erased in 0.125 s
CMT NOR area [00040000-000BFFFF] erased in 0.203 s
CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
CMT NOR area [00140000-0137FFFF] erased in 4.265 s
CMT NOR area [01380000-0151FFFF] erased in 0.453 s
Flash programming ...
Error chk C7012D0103CD000010000000F1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00040000, Result: 0010
RX Buffer: C7012D0103CD000010000000F172
Help ME
EXPERTS
Old 04-05-2011, 12:35   #2 (permalink)
lucky121's Avatar
Member: 559810
Sonork: Not use
Thanks Meter: 176
dear check ur Cable Modified or Use GPG cable
The Following User Says Thank You to lucky121 For This Useful Post:
Old 04-05-2011, 12:36   #3 (permalink)
Member: 732119
Thanks Meter: 64
I Check Ten Pieces Of Cable
And I Am Sure Cable Is Good
Anyone ?
Old 04-05-2011, 12:39   #4 (permalink)
allentelecom's Avatar
Member: 200633
Thanks Meter: 59
check or change your loader configuration brother....used new loader
The Following User Says Thank You to allentelecom For This Useful Post:
Old 04-05-2011, 12:45   #5 (permalink)
Member: 732119
Thanks Meter: 64
Can U Explain Bro
For Better Compliment?
Old 04-05-2011, 12:51   #6 (permalink)
syed jewel's Avatar
Member: 1067276
Sonork: 100.1591989
Thanks Meter: 654
Originally Posted by bilalahmad View Post
Can U Explain Bro
ok bro this problem show cable no problem flash with usb i am sure you try flash with hwk done with this cable
The Following User Says Thank You to syed jewel For This Useful Post:
Old 04-05-2011, 12:54   #7 (permalink)
Member: 732119
Thanks Meter: 64
Thanks Bro For Response
But Mcu Has Been Erased
That Means USB Flashing Is Not Possible
ANYONE ?
Old 04-05-2011, 12:56   #8 (permalink)
totmititelu's Avatar
Member: 880649
Thanks Meter: 73
I think is better to flash your 2690 by USB ---DEAD USB , if the PCB is not fault, it wil write ok. I see you use UFS box.. but not allways is the best box to connect BB5 on MX-key for flashing
The Following User Says Thank You to totmititelu For This Useful Post:
Old 04-05-2011, 13:00   #9 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
ANYONE ?
yes cmt part of phone is erased then onley f-bus cable help you for solve problem ...\
better use gpg or mx-key tested f-bus cable .....
no usb flashing recover cmt erased phone .....
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
Old 04-05-2011, 13:01   #10 (permalink)
Member: 732119
Thanks Meter: 64
Great Description Bro
But Mention That
I Use Ub And Mt Also NOT Only Mx Key And Ufs
But Programing Error Boss
And U R TALKING ABT THE DEAD USB
MCU HAS BEEN ERASED FROM HANDSET
THAT MEANS USB FLASHING IS IMPOSSIBLE
Help me
Old 04-05-2011, 13:03   #11 (permalink)
Member: 732119
Thanks Meter: 64
Sir I mEntion in The Ab ove Post
That Cable Is Good
Old 04-05-2011, 13:07   #12 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
i have same problem some day before then use hwk for flashing and skip erase then my set flash complete and working well so try out ...
Old 04-05-2011, 13:09   #13 (permalink)
Member: 732119
Thanks Meter: 64
Here Is Log
When I Skip Erase
1ST BOOT  : C0,07 [Rm-635] [2.1.0.0]
RAPx ID   : 000000010000022600010006030C192101033000
EM 1 ID   : 00000296
EM 2 ID   : 00000B22
RAPx PBID : 1C40020FDF7601563E0298A3FF2F5596686F2799
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00EC2400-00008A31, Sam K8x1259ETF
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO  : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT VPP   : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm635__10.10.mcusw
ERASE Skipped
DATA_BLK_ERROR at: 0x00040000, 00
ERR: CMT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x000240, Time: 10:45
Process Failed, Repowering Mobile
Old 04-05-2011, 13:10   #14 (permalink)
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
chek mark still on dual line and 1331
Old 04-05-2011, 13:14   #15 (permalink)
Member: 732119
Thanks Meter: 64
Thanks For Response
But Both R Marked Dual Line As Well As 1331
And I Also Try
Unmarked Condition Also
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.32838 seconds with 9 queries
