11-26-2009, 02:53 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1166401 Status: Offline Thanks Meter: 5 | MX-KEY failed to RESET to Factory Settings but factory resets works fine when i set option to do factory settings while flashing.. any other user experienced this problem ? |
11-26-2009, 02:57 | #2 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | will you be please to post log of RESET to Factory Settings from mx key from a working bb5 set? here not yet noticed such an error . regards, NEIL |
11-26-2009, 03:05 | #3 (permalink) |
Member: 1166401 Status: Offline Thanks Meter: 5 | Its log is nothing .. it displayes as all are done OK... OK .... But the actually only security code were reseted ... userdata still in phone memory. Next time you just try "Bus Check" and "Reset All" . Post your result. |
11-26-2009, 03:14 | #5 (permalink) |
Freak Poster Join Date: Dec 2006 Location: gsmworld of moderetso .
Member: 410890 Status: Offline Thanks Meter: 88 | here try this go in imei and security tab then click read or write new select phone memory to change sec code or reset it there.....and make sure use ufs and update your usb version and modify also your jaf box if you use jaf to perform test mode accurate.. |
11-26-2009, 07:28 | #6 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
all is done OK but the phonebook and images is not erased , any solution ? | |
how to write rpl w/ mx key like rpl plain in jaf sets | lorenzo roberto | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-18-2009 20:17 |
3110c Failed to RESET FULL FACTORY ? | blue_life1111 | J.A.F. By Jafsupport.com | 6 | 11-28-2007 19:23 |
how to reset to factory settings Nec N21I | tasta | NEC | 2 | 08-18-2004 15:04 |
How to reset full factory on 6210??? | zDEnaL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-20-2002 04:14 |
