02-15-2010, 09:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: pakistan Age: 34
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | mx-key imei repair error SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D02509:2984DA60 ASIC type: 2 UEM Imei: 30551301102502 Connecting to server ...OK, Login ... Hello C08056BC, you have 920 credits left. Invalid DATA1 length, expected: 80 chars. i chech two difrent fone but same erorr plz tell me what is this |
02-15-2010, 10:25 | #2 (permalink) |
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D02509:2984DA60 ASIC type: 2 UEM Imei: 30551301102502 Connecting to server ...OK, Login ... Hello C08056BC, you have 920 credits left. Invalid DATA1 length, expected: 80 chars. |
02-15-2010, 17:29 | #5 (permalink) |
Insane Poster Join Date: Sep 2006 Location: India(Assam) Age: 60
Member: 359015 Status: Offline Sonork: tarunshan Thanks Meter: 13 | Yes. Today I also found this trouble for 1600. conecting to server ok....login........ hellow c0905BASSE, you have 1960 credits left. Invalid data length, expected; 80 chars. |
02-15-2010, 21:16 | #8 (permalink) |
Banned Join Date: Jul 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 318781 Status: Offline Thanks Meter: 50 | not working what happend there is a lot of bugs in new update 1.6 and when i connect ufs bus check is always says Ram problem what should i do is there problem with update or my box error |
02-17-2010, 06:50 | #9 (permalink) |
Member: 294245 Status: Offline Sonork: 100.1602405 Thanks Meter: 115 | ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0042CB05:2984DA60 ASIC type: 2 UEM Imei: 35838100509247 Connecting to server ...OK, Login ... Hello C08056BC, you have 920 credits left. Invalid DATA1 length, expected: 80 chars. |
02-17-2010, 06:59 | #10 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Code: Connecting to server ...OK, Login ... Hello C060xxxx, you have 9980 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35838100509247.RPL" Code: [SER_PROG_DATA_OUT] IMEI=35838100509247 DATA1=93F6399E6DB70CF11F569747916607C27DEEE5253DAD1B042ADF0BE10A80921C337AD96B4230FCC3 DATA2=1CD47E16C83E70D30D708E8D809EE40CA157CF0E01787492426A608A1EEB455DBE22AFD99350223EA6E8E4D1B616FA63A38C0695518C6ABDB7407CDDB06564C2FCB7CEF0FAFF2E7A51E7D899107C067FF73F78DCAC093296 br, Last edited by Andra; 02-17-2010 at 07:02. Reason: add rpl file |
MX-KEY SD repair was FIXed...!!!! Great Job from Great TEAM | togelmania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 14:12 |
LOL::: MX-KEY SD Repair Not work:: | burhan barq | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 02-03-2010 16:10 |
MX-Key SD repair now in Beta test..!!! | Cyclone Team<3 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-03-2010 11:55 |
1200 ???????? imei convert to 1208 try to repair imei by mx-key but some error appear | mine4ever | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-16-2010 13:36 |
mx-key config repair Successfully %100 ok %100 tested 20 phones | caferimm68 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 11-18-2009 08:57 |
