01-28-2010, 14:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: MX-KEY is the BEST NOKIA TOOL
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | mx-key interface error what am i doing wrong i have attached a screenshot, i tried to uninstall , delete mobileEx folder , reinstall but still same error |
01-28-2010, 15:08 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | Quote:
which version was there before and was it working well?if you were using it perfectly before then probably you need to download a fresh copy.after that ensure your interfaces are working well with their original softwares i.e jaf with the jaf software and saras box with the hwk or saras soft on that same computer.after installing there is a window adjacent connect button.right inside that window click in it and it should show you the available interfaces.then press connect. | |
mx-key Interface not open show this erore | aukonline | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-07-2009 19:23 |
mx-key flash error | masum_sohel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 08-03-2009 08:14 |
mx key pasword error | sendok | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 07-03-2009 02:10 |
mx key interface not connecting? | SAN INFOTECH | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-01-2009 04:52 |
MX KEY loging error | lucky121 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-07-2009 05:04 |
